    • RB-CCB Rotor kit (390/360) for Ford Mustang Dark Horse (2024+) Upgrade Conversion from Iron Rotors Front & Rear (P/N 2R11 & 2R68)
  • Rotor Kit
  • Front
  • Rear
  • Front Weight
  • Rear Weight
  • Front Caliper
  • Rear Caliper
  • Rear Brake
  • Rotor Kit Front Rear Front Weight Rear Weight Front Caliper Rear Caliper Rear Brake
    MSRP: $12,000.00
    Now: $11,400.00
    (You save $600.00 )
    FOR-CRK-390.360
    Expected release date is Jun 16th 2025
    • 2 ea Front ccb rotors (390x36mm =OE size)
    • 2 ea Rear ccb rotors (360x28mm vs. OE 355x28)
    • 2 ea Rear caliper spacers - This spacer kit can enable rotor for a perfect kit to OE calipers (better than OE fitment)
    • 1 car set of ccb brake pads ($1,066 value)
    This ccb rotor kit is designed and made for a direct replacement conversion from OE's iron rotors w/o requiring any modifications and fit better than OE iron rotor setup.
    Feature and benefits:
    1. Discs are made with continuous carbon fibers (vs. Brembo's chopped fibers) and RB's exclusive design with angle vanes vs. Brembo and ST (Surface Transforms) straight vane for a more efficient cooling.
    2. See comparison on three different designs in discs.
    3. Rotor kit includes RB's ST600 brake pads exclusively developed for Carbon Ceramic Rotors for street and spirited driving.
    4. ST600 is a compound can cover a wide range of temperature, from cold winter morning right out of garage to elevated temperature.
    Weight comparison:
    • Front: CR46
    • Rear: CR24
    • Front: PD1395-360
    • Rear: PD592M-360
    Rotor Kit
    • RB 2 pc Rotor Kit (390/360) for Ford Mustang GT Dark Horse (2024+) Replacement Front & Rear (P/N 2727 & 2728) Rear kit
      MSRP: $2,885.00
      Now: $2,740.00
      MSRP: $10,500.00
      Now: $9,975.00
      MSRP: $14,348.41
      Now: $13,630.00
      MSRP: $10,500.00
      Now: $9,975.00
    • rotor kit front rotor
      RB-CCB Rotor Kit (380x34) for Ford Mustang GT550 2015+, V8 Perf., Mach 1 (2021+) Front Upgrade CCB Conversion from Stock Iron Rotors
      MSRP: $6,820.00
      Now: $6,479.00
