          • LANCER (08-16) EVO 10
          • LANCER (03+06) EVO 8-9
          • EVORA (2009-2021)
    • Carbon Ceramic Brake System Kit (390/410) for Ferrari F50 (95-97) Front & Rear (P/N 2R63-K & 2R64-K)
          • EVORA (2009-2021)
    MSRP: $36,000.00
    Now: $34,200.00
    (You save $1,800.00 )
    FF-CRK-390.410
    Installation notes:
    This bbk will be a highly customized and precisely engineered brake system kit.
    For example the rotor are over-sized in a way so they are staggered like OE by keeping them in the same increments  in diameter (55mm or 2.2").
    • Front: OE 335mm + 55mm (2.2") = 390mm - fits 20" wheels
    • Rear: OE 355mm + 55mm (2.2") = 410mm - fits 20/21" wheels
    The calipers will also be upgraded/oversized to 6/4 pot with a substantially larger brake pads from OE's 4/4 pot.
    Kit Includes:
    • 2 ea RB6LA 6-pot front brake calipers (vs. OE 4-pot calipers)
    • 2 ea front caliper adaptors w/hardware
    • 2 ea front CCB rotors (390x36mm vs. stock 335x32mm iron rotors)
    • 2 ea RB4L2 4-pot rear brake calipers
    • 2 ea rear caliper adaptors w/hardware
    • 2 ea rear CCB rotors (410x30mm vs. stock 355x32mm iron rotors)
    • 2 ea rear parking brake caliper adaptors w/hardware
    • 1 car set CCB brake pads
    • 1 car set SS brake lines
    • Front: PD1395-360
    • Rear: PD-1165
    Replacement brake discs:
    • Front: CR49
    • Rear: CR29
    Feature & benefit:
    • Replacing stock smaller/rusty outdated iron rotors to the modern ccb brakes.
    • Center Lock bolt-on easy installation.
    • CCM rotors have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack (due to the heat). More advantageous for tracking/racing with proper brake pads.
    • Literally no brake dust.
    • Improve driving comfort.
    Avoid:
    F50 Specs. (Source: https://www.supercars.net/blog/all-brands/ferrari/ferrari-f50/)
    • Manufacturer: Ferrari S.p.A.
    • Production:1995–1997
    • Units:349 produced
    • Assembly: Maranello, Italy
    • Designer: Pietro Camardella and Lorenzo Ramaciotti
    • Class: Sports car (S)
    • Body style:2-door Targa
    • Layout: Rear mid-engine, RWD
    • Engine:7L DOHC 65 degree Tipo F130B V12
    • Power:382 kW (519 PS; 512 hp)
    • Transmission:6-speed manual
    • Wheelbase:2,580 mm (101.6 in)
    • Length:4,480 mm (176.4 in)
    • Width:1,986 mm (78.2 in)
    • Height:1,120 mm (44.1 in)
    • Curb weight:1,400 kg (3,080 lb)
    • Predecessor: Ferrari F40
    • Successor: Ferrari Enzo
    • Carbon Ceramic Brake System Kit (420/410) for Tesla X Plaid Front & Rear (P/N 2R58-K & 2R49-K) Carbon Ceramic Brake System Kit (420/410) for Tesla X Plaid Front & Rear (P/N 2R58-K & 2R49-K)
      MSRP: $17,850.00
      Now: $16,960.00
    • Carbon Ceramic Brake System Kit (420/410) for Tesla Plaid & LR Front & Rear (P/N 2R44-K & 2R49-K) Carbon Ceramic Brake System Kit (420/410) for Tesla Plaid & LR Front & Rear (P/N 2R44-K & 2R49-K)
      MSRP: $17,850.00
      Now: $16,960.00
    • front front
      MSRP: $16,565.00
      Now: $15,786.75
    • RB System Brake Kit (420x40/370x30) for Mustang GT500 Front and Rear (P/N 2640-K & 2641-K)
      MSRP: $9,400.00
      Now: $8,930.00
    • Typical brake kit Front rotor
      RB Calipers Brake System Kit (380/380mm) for Ferrari models 348/355 (300/310mm) Upgrade Front & Rear (P/N 2362-K & 2363-K)
      MSRP: $7,579.00
      Now: $7,200.05
