    • RB Calipers Brake System Kit (380/380mm) for Ferrari models 348/355 (300/310mm) Upgrade Front & Rear (P/N 2362-K & 2363-K)
  • Typical brake kit
  • Front rotor
  • Rear rotor
  • Typical brake kit Front rotor Rear rotor
    MSRP: $8,900.00
    Now: $8,455.00
    (You save $445.00 )
    FER-IRP-01
    Bulk Pricing:
    Buy in bulk and save
    Bulk discount rates
    • Buy 2 - 4 and get 5% off
    • Buy 5 or above and get 10% off
    Expected release date is Feb 15th 2024
    This kit includes:
    • 2 ea RB 6-pot front calipers (6061-T6 forged aluminum alloy)
    • 2 ea Front caliper adaptors
    • 2 ea Front lightweight 2 pc rotors (380x34 vs. OE 300x28mm)
    • 2 ea RB 4-pot rear calipers
    • 2 ea Rear caliper adaptors
    • 2 ea Rear lightweight 2 pc rotors (380x39mm vs. OE 310x24mm)
    • 1 car set (Front & Rear) street brake pads
    • 1 car set SS brake lines
    This system brake kit is designed with oversized rotors and calipers allowing with extra thermal capacity for handling heavy duty braking tasks. It generally requires 19" wheels to install, however we recommend downloading the fitment templates below (only front kit test is sufficient) to make sure the kit can fit under your existing wheels or new wheels be acauired before purchasing the kit.
    • Front kit: 2362-K Ferrari 355 Front BBK (380).pdf
    • Rear Kit: 2363-K Ferrari 355 Rear BBK (380).pdf
    • Front: PD1666M
    • Rear: PD698
    Replacement rotor discs:
    • Front: D501-04
    • Rear: D601-04
    Rotor weight info:
    • Front rotor/ea: 380x34mm (24.5 lbs)
    • Rear rotor/ea: 380x30mm (20 lbs)
    Typical brake kit
    • RB Brake System Upgrade Kit (380/365) for Tesla Model S/X Front & Rear (P/N 2466-K & 2435-K). Select Option if you have 1-piston rear calipers (Mando). RB Brake System Upgrade Kit (380/365) for Tesla Model S/X Front & Rear (P/N 2466-K & 2435-K). Select Option if you have 1-piston rear calipers (Mando).
      MSRP: $6,650.00
      Now: $6,320.00
    • RB BBK (380/380mm) Front & Rear for 2023 Z (RZ34), G37/370Z (P/N 2593-K & 2594-K) RB BBK (380/380mm) Front & Rear for 2023 Z (RZ34), G37/370Z (P/N 2593-K & 2594-K)
      MSRP: $7,500.00
      Now: $7,125.00
    • RB 15" BBK (380/380mm) - Front & Rear for 350Z/Infiniti G35/Skyline R34 (P/N 2121-K & 2594-K)
      MSRP: $7,360.00
      Now: $6,998.00
    • RB BBK (380/365) for Tesla Model 3 Front+Rear (P/N 2605-K & 2633-K) Rear
      MSRP: $6,260.00
      Now: $5,950.00
    • RB System Brake Kit (420x40/370x30) for Mustang GT500 Front and Rear (P/N 2640-K & 2641-K)
      MSRP: $9,400.00
      Now: $8,930.00
