Quick view sku: PD-BMW-391 [PD2155_75/PD2059-391] Brake Pads for Iron Rotors - BMW M3/M4 G82/83 (21+); M5 F90 (2018+); M8 (2020+) for CCB to Iron Conversion Front & Rear MSRP: $632.00 Was: Now: $598.85 Choose Options Compare Quick view sku: BMW-ccb-iron-400.380 RB 2Pc Rotor kit (400/380) for M5 F90, M3/M4 G8x CCB to Iron Rotor Conversion (P/N 2725 & 2645) MSRP: $3,320.00 Was: Now: $3,155.00 Choose Options Compare Quick view sku: BMW-IRK-390.380 Save 10% on RB 2pc Rotor Kit (390x36/380x28) for BMW M5 F90 Stock Replacement (P/N 2644 & 2645) MSRP: $2,950.00 Was: Now: $2,802.50 Choose Options Compare Quick view [PD2155_75/PD2059-391] Brake Pads for Iron Rotors - BMW M3/M4 G82/83 (21+); M5 F90 (2018+); M8 (2020+) for CCB to Iron Conversion Front & Rear The front pads have been modified to 75mm depth to better fit the iron rotor rings (vs. 87mm for ccb rotors) Fit the following calipers: Front Caliper: Rear Caliper: MSRP: $632.00 Was: Now: $598.85 Choose Options Compare Quick view RB 2Pc Rotor kit (400/380) for M5 F90, M3/M4 G8x CCB to Iron Rotor Conversion (P/N 2725 & 2645) Installation note: Rotor kits are made for ccb to iron rotor downgrade conversion with a 100% "bolt on installation" w/o modifications. Kit contents: 2 ea. Front 2 pc rotors (400x38mm) 2 ea. Rear 2 pc rotors (380x28mm) 1 set brake pads... MSRP: $3,320.00 Was: Now: $3,155.00 Choose Options Compare Quick view Save 10% on RB 2pc Rotor Kit (390x36/380x28) for BMW M5 F90 Stock Replacement (P/N 2644 & 2645) Kit includes: 2 ea Front 2 pc rotors 390*x36mm (vs. OE 395x36mm). 2 ea Rear 2 pc rotors 380x28mm Brake pads (optional) *Actual pad contact rotor diameter is only 390mm, so our 390mm rotor can eliminate undesirable rusty lip developed after... MSRP: $2,950.00 Was: Now: $2,802.50 Choose Options Compare Compare Selected × OK
