    MSRP: $10,500.00
    Now: $9,975.00
    (You save $525.00 )
    DOD-VIP-360.360
    • 2 ea Front ccb rotors (360x32mm vs. OE 355x32mm)
    • 1 set Caliper spacer kit for the front BBK
    • 2 ea Rear ccb rotors (360x32mm vs. OE 355x32mm)
    • 1 set Caliper spacer kit for the rear BBK
    • 1 car set ccb brake pads (Optional)
    Features and benefits:
    1. Retain the use of OE calipers
    2. Converting/Upgrade to ccb.
    3. Direct bolt on installation.
    4. Dramatic unsprung weight reduction.
    5. Great value for iron rotors conversion upgrade.
    6. Rotors are made of continuous carbon fiber much more stronger than OE/Brembo ccb.
    7. Rotors are directional vanes for a more efficient cooling.
    8. Lower maintenance & replacement cost than OE/Brembo CCM rotors.
    • Front & Rear pad: PD1165-360
    Replacement discs:
    • Front/rear disc: CR30
    Application notes:
    This rotor kit is made for conversion upgrade to ccb, due to the constraint of OE caliper & pad sizes we do not recommended this setup for tracking.
    See this full track racing ccb system kit for your consideration.
    Installation review:
    RacingBrake Carbon Ceramic Rotor Install
      MSRP: $9,400.00
      Now: $8,930.00
    • RB-CCB System Kit (380/360) for Dodge Viper G3/4/5 (P/N 2C44-K & 2C72-K) FRONT
      MSRP: $15,600.00
      Now: $14,820.00
    • RB-CCB Rotor Kit (390/360mm) for Dodge Viper G3-G5 Upgrade to CCB Front & Rear (P/N 2C71 & 2C72) Note: Required front OE 6 pot callipers are not included (available at option) Front
      MSRP: $13,600.00
      Now: $12,920.00
    • RB-CCB Rotor Kit (394/360) for Camaro G6 (2016+) ZL1, 1LE & Cadillac V3 Conversion Upgrade Fits OE Calipers (P/N 2C85 & 2R12) RB-CCB Rotor Kit (394/360) for Camaro G6 (2016+) ZL1, 1LE & Cadillac V3 Conversion Upgrade Fits OE Calipers (P/N 2C85 & 2R12)
      Now: $12,350.00
      Now: $12,400.00
