    • RB BBK Rotor Kit (390/355) for Viper G3-G5 Retrofit to ACR-E 6 Pot CCB Front Caliper; Re-use Rear OE Calipers (P/N 2497-K & 2219-K)
    MSRP: $5,050.00
    Now: $4,795.00
    (You save $255.00 )
    DOD-IRP-02
    This brake kit is ideal for upgrading your Viper G3/4/5 to ACRE CCB brake setup with 6 pot calipers and larger rotors on front.
    Leadtime is subject to OE calipers availability which will be confirmed upon receipt of order.
    Kit includes
    • 2 ea New OE 6 pot CCB calipers (Optional)
    • 2 ea RB lightweight 2 pc front rotors (390x34mm vs. OE 355x32mm w/4 pot calipers)
    • 2 ea RB lightweight 2 pc rear rotors (355x32mm) Reuse your rear stock 4 pot calipers to complete the installation.
    • 1 car set street brake pads (Optional).
    Front: PD1395
    Rear: PD968
    Front: D602-01
    Rear: D403-06
    Design concept and goal:
    This retrofit BBK system has been reviewed and approved by RB for tracking/racing as well as street driving with proper selection of brake pad compound.
    Rotors are designed and built by RB featuring center mount design for more efficient cooling than conventional surface mount.
    The most cost effective and easiest way (100% bolt-on) to upgrade your existing brake, update to the same as the "latest" ACRE configuration for performance improvement and look w/o costing you an expensive CCB set up.
    For more information see Viper Forum.
    Installation review: Viper Owners Association
    • RB 6 Pot Front Calipers & OE Rear Caliper BBK (380x34/370x24) for Toyota Supra MK5 (P/N 2657-K & 2656-K) RB 6 Pot Front Calipers & OE Rear Caliper BBK (380x34/370x24) for Toyota Supra MK5 (P/N 2657-K & 2656-K)
      MSRP: $6,138.00
      Now: $5,831.10
    • RB-CCB Rotor Kit (390/360mm) for Dodge Viper G3-G5 Upgrade to CCB Front & Rear (P/N 2C71 & 2C72) Note: Required front OE 6 pot callipers are not included (available at option) Front
      MSRP: $13,600.00
      Now: $12,920.00
    • RB Rotor Kit (355/355mm) for Tesla M3 (Standard or Perf. Model) OE Calipers BBK (P/N 2603-K & 2608-K) RB Rotor Kit (355/355mm) for Tesla M3 (Standard or Perf. Model) OE Calipers BBK (P/N 2603-K & 2608-K)
      MSRP: $2,860.00
      Now: $2,717.00
    • RB BBK (390/380mm) - Front & Rear for 350Z/Infiniti G35/Skyline R34 (P/N 2465-K & 2594-K) Retrofit to R35 GTR Brembo 6/4 Pot Calipers Front adaptor
      Now: $4,515.00
    • RB OE Caliper BBK (365/355) for Tesla M3 (Std Model) (P/N 2602-K & 2608-K) FRONT
      MSRP: $2,880.00
      Now: $2,686.00
