    • Save 10% on RB 2 pc Rotor Bundle Kit (355/355) for Dodge Viper 2013+ Repl. (P/N 2343 & 2219)
  • TA pads - 60mm depth
  • Standard pad - 53mm depth (Non-TA)
  • Save 10% on RB 2 pc Rotor Bundle Kit (355/355) for Dodge Viper 2013+ Repl. (P/N 2343 & 2219) TA pads - 60mm depth Standard pad - 53mm depth (Non-TA)
    MSRP: $2,560.00
    Now: $2,430.00
    (You save $130.00 )
    DOD-IRK-02
    • 2 ea 2 pc front rotors (355x32mm)
    • 2 ea 2 pc rear rotors (355x32mm)
    • 1 set caliper spacers to shim up the calipers to better fit the rotor edge (see illustration below)
    • 1 set brake pads - Optional
    Rotors are made to replace stock Brembo 2 pc rotors on ACR-X with TA pads or as an upgrade for both ACR & non ACR models from 2003 and up.
    Replacement components:
    • Front pads: PD1001 (=TA pads)-RB rotors have wider annulus for more pad coverage than OE (60mm vs OE 52mm)
    • Rear pads: PD968  (Same as Non TA front pads)
    • Rotor rings: D403-06 (Same for front & Rear)
    The OE pad edge contact diameter is only 348mm resulting a 3.5mm rusty rings with a 355mm rotor. We include a spacer kit for installing (between the spindle and caliper) for a perfect fit which can also increase the braking performance for a larger pad swiping area and better look with the elimination of the undesirable rusty lips.
    VS.
    RB 2pc rotor kit includes a caliper spacer kit (front & rear) for a proper alignment between the brake pad and rotor edge. (Not applicable for used rotors which the lips already formed)
    Spacers are to be installed between caliper and spindle.
    RB Kit Advantages:
    • TA pads (Larger than non-TA pads)
    • Increase the pad swiping area (larger rotor diameter 355 vs. 348mm) and friction efficiency
    • Eliminate the undesirable rusty lips
    • Better performance and look.
    Forum Discussion:
    TA Replacement Rotors from Racing Brakes
    • Save 10% on RB 2 pc Rotor Bundle Kit; BBK Front; Stock Rear (370/355) for Dodge Viper 2013+ (P/N 2504 & 2546) TA pads - 60mm depth
      MSRP: $2,895.00
      Now: $2,750.00
    • Save 10% on RB 2pc Rotor Bundle Kit (355/335) for Tesla M3P (Perf. Model) Stock Replacement Front & Rear (P/N 2604 & 2623) Save 10% on RB 2pc Rotor Bundle Kit (355/335) for Tesla M3P (Perf. Model) Stock Replacement Front & Rear (P/N 2604 & 2623)
      MSRP: $2,631.20
      Now: $2,499.64
    • RB 2 Pc Rotor Kit for Dodge Viper G6 - CCB Conversion to Iron (P/N 2497 & 2498)
      MSRP: $3,200.00
      Now: $3,040.00
    • RB 2pc Rotor Kit (365/355) for Audi R8 (P/N 2339 & 2340)
      MSRP: $2,517.90
      Now: $2,392.01
    • Save 10% on RB 2pc Rotor Stock Replacement Bundle Kit (355/365) for Tesla Model S (12-20) & X  (15+) Front & Rear (P/N 2434 & 2435) Front
      MSRP: $2,800.00
      Now: $2,660.00
