    • RB-CCB Rotor Kit (390/360mm) for Dodge Viper G3-G5 Upgrade to CCB Front & Rear (P/N 2C71 & 2C72) Note: Required front OE 6 pot callipers are not included (available at option)
  • Front
  • Rear
  • RB-CCB Rotor Kit (390/360mm) for Dodge Viper G3-G5 Upgrade to CCB Front & Rear (P/N 2C71 & 2C72) Note: Required front OE 6 pot callipers are not included (available at option) Front Rear
    MSRP: $13,600.00
    Now: $12,920.00
    (You save $680.00 )
    DOD-CRK-G3_G5-390.360
    Kit Includes:
    • 2 ea front CCB rotors (390x34mm)
    • 2 ea rear CCB rotors (360x32mm)
    • 1 car set CCB brake pads (optional)
    This valuable RB-CCB rotor kit is specially made for G3-G5 Viper owners to upgrade their stock 4/4 pot calipers (355/355mm) iron rotors, to the moden 6/4 pot calipers and latest CCB rotor technology.
    Learn how RB CCM rotors are made differently from OE/Brembo.
    https://racingbrake.com/tech-info/
    RB ST600 has Performance characteristics that is comparable to Pagid RSC1 or OE Brembo.
    • Excellent modulation
    • Literally dust free
    • No squeak
    • Highly durable
    • Front: PD1395-360
    • Rear: PD1165-360
    Replacement brake discs:
    • Front: CR18
    • Rear: CR30
    Installation of this kit requires front 6 pot ACRE OE calipers which are available at option.
    The rear CCB rotor kit is made to the same offset as G3-G5 stock iron rotor so they will simply be a direct swap installation although you can also opt at the option you can opt RB calipers for a better "balanced" brake system.
    • Re-use the stock calipers for money saving or
    • Purchase RB 4 pot calipers which is highly recommend to properly match with the new ACRE 6 pot calipers (piston area 55 vs. stock front 4 pot @55.5 cm^2) for such a major investment on your brakes.
    • If you plan to acquire ACRE new rear 4 pot calipers for a proper bias, you must also swap your G3-G5 rear spindle to ACRE because the ACRE's rear 4 pot caliper has a different offset than G3-G5 rear calipers.
    Recommended readings:
    Racing Brakes Rear Bias Kit Evaluation
    ACR CCB's on non ACR Gen V
    • RB-CCB Rotor Kit (390/360mm) for Dodge Viper ACRE CCB Direct Repl. Front & Rear (P/N 2C71 & 2C93) Front
      MSRP: $12,600.00
      Now: $11,970.00
      MSRP: $10,500.00
      Now: $9,975.00
    • RB BBK Rotor Kit (390/355) for Viper G3-G5 Retrofit to ACR-E 6 Pot CCB Front Caliper; Re-use Rear OE Calipers (P/N 2497-K & 2219-K)
      MSRP: $5,050.00
      Now: $4,795.00
      MSRP: $10,500.00
      Now: $9,975.00
    • RB-CCB System Kit (380/360) for Dodge Viper G3/4/5 (P/N 2C44-K & 2C72-K) FRONT
      MSRP: $15,600.00
      Now: $14,820.00
