Quick view [PD-AM-360] RB Pads Kit for CCM Rotors - Aston Martin DB9 04-16; Vanquish, 12-18; Vantage V12S 13+ Front and Rear (PD1395B & PD1165) - ST600 MSRP: Was: Now: $0.00 Choose Options Compare Quick view RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DBS 11+ (2017+ w/128mm Bolt Hole Circle) Front and Rear (P/N 2699 & 2700) MSRP: $3,800.00 Was: Now: $3,610.00 Choose Options Compare Quick view [PD-AM-360] RB Pads Kit for CCM Rotors - Aston Martin DB9 04-16; Vanquish, 12-18; Vantage V12S 13+ Front and Rear (PD1395B & PD1165) - ST600 You save 10% when buying front and rear pads together vs. purchasing separately. Here is the link if you would like to purchase individually: Front: PD1395B-360 Rear: PD1165-360 MSRP: Was: Now: $0.00 Choose Options Compare Quick view RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DBS 11+ (2017+ w/128mm Bolt Hole Circle) Front and Rear (P/N 2699 & 2700) This rotor and pad kit is specially made for converting OE CCB to Iron rotors (DB11 2017+) with a 100% bolt on installation. Not only it can eliminate that annoying squeaks from OE CCB rotors but lower your maintenance & replacement cost... MSRP: $3,800.00 Was: Now: $3,610.00 Choose Options Compare Compare Selected × OK
