    • Rotor Ring Replacements (400x32mm) - Price per pair (Incl. hardware)
    MSRP: $1,000.00
    Now: $950.00
    (You save $50.00 )
    D603-09-381
    Machining: Open Slot
    Surface: EDP Coating w/cross cut grinding
    Note on brake pad choice:
    If you are ungrading to this rotor from stock size, this rotor ring can accomondate the larger (deeper) pads for your S Plaid which can be purchased here, to enhance the overall braking performance by keeping the braking temperature lower, rather than upgrading rotor only and still keep the small stock size pad.
    Pdts2021_65
    • Rotor Ring Replacements (390x33) - Price per pair (Incl. hardware)
      MSRP: $1,100.00
      Now: $950.00
    • Rotor Ring Replacements (410x34) - Price per pair (Incl. hardware)
      MSRP: $1,000.00
      Now: $950.00
    • Rotor Ring Replacements (400x28mm) - Price per pair (Incl. hardware)
      MSRP: $1,000.00
      Now: $950.00
    • Rotor Ring Replacements (390x28)- Price per pair (Incl. hardware)
      MSRP: $984.50
      Now: $935.28
    • Rotor Ring Replacements (380x30)- Price per pair (Incl. hardware)
      MSRP: $919.60
      Now: $873.62
