    • Replacement Rotor Ring (Drill+Slot) for RB 4 Pot Caliper Kits
    MSRP: $636.90
    Now: $605.06
    (You save $31.84 )
    D306-01-351
    Comes with the necessary hardware for each disc.
    Machining: Straight Slot
    Surface: EDP Coating w/cross cut grinding
    • (Black DPI  Coating) (after a few stops)
      RB 2pc Replacement Rotor Rings - Drilled & slotted - (300x22mm) Includes hardware
      MSRP: $613.80
      Now: $583.11
    • Rotor Rings (365x36) for RAM 3500 Front - RB 6 pot caliper kit 2 pc Rotor Replacement (Price is for pair) - Hardware are included.
      MSRP: $767.00
      Now: $729.00
    • Replacement Rotor Ring (Drill+Slot) for  CORVETTE Z06 REAR Replacement Rotor Ring (Drill+Slot) for  CORVETTE Z06 REAR
      MSRP: $613.80
      Now: $583.11
    • Replacement Rotor Ring (Slotted) 350x23 for RB 2pc Rotor Rear (Incl. hardware)
      MSRP: $672.10
      Now: $638.50
    • image_8200
      RB Repl Rotor Ring 316x28mm (Drill+Slot) (Incl. Hardware)
      MSRP: $509.30
      Now: $483.84
