    • RB Repl Rotor Ring 316x28mm (Drill+Slot) (Incl. Hardware)
  • image_8200
  • image_8200
    MSRP: $509.30
    Now: $483.84
    (You save $25.46 )
    D216-07-351
    Comes with the necessary hardware for each disc.
    Machining: Drilled & Slotted
    Surface: EDP Coating w/cross cut grind
    image_8200
    • image_8199 RB Repl Rotor Ring (one pair) 316x28mm (Slotted) (Incl. Hardware)
      MSRP: $509.30
      Now: $483.84
    • image_8187
      Rotor Ring (Drill-Slotted) - 296x32mm FRONT (Incl. hardware)
      MSRP: $486.20
      Now: $461.89
    • image_8197
      Rotor Ring (Drill+Slot) -M3 (E36) FRONT (Incl. hardware)
      MSRP: $617.10
      Now: $586.25
    • image_8263
      Rotor Ring (Slot) - 355x30mm (Incl. hardware)
      MSRP: $684.20
      Now: $649.99
    • Replacement Rotor Ring (Slotted) 350x23 for RB 2pc Rotor Rear (Incl. hardware)
      MSRP: $672.10
      Now: $638.50
