    • 300x12mm Replacement Rotor Rings (Curved Slot) Incl. hardware
    MSRP: $605.00
    Now: $575.00
    (You save $30.00 )
    D008-01-321
    Comes with the necessary hardware for each disc.
    Material:
    1. Racing Formula Alloyed Gray Iron & Heat treated. Alloyed iron formula adds strength and heat resistance.
    2. Heat treating to further improves rotor performance and durability.
    Disc feature:
    • Dimensions: 300x12mm
    • Weight: 7.8 lbs/ea (estd)
    • Mounting PCD=168.5mm
    • Offset = 7mm
    • Rotor Ring Replacements (Curve-Slotted) - 340x31mm (Incl. hardware)
      MSRP: $562.10
      Now: $534.00
    • 330x12mm Replacement Rotor Rings (Curved Slot) Incl. hardware
      MSRP: $605.00
      Now: $575.00
    • 350x12mm Replacement Rotor Rings (Curved Slot) Incl. hardware
      MSRP: $605.00
      Now: $575.00
    • Rotor Ring Replacements (Incl. hardware)
      MSRP: $792.00
      Now: $752.40
    • image_8158
      Rotor Ring (Curve Slot) - MIATA MX5 REAR (Incl. hardware)-1581026344
      MSRP: $395.00
      Now: $375.00
