    • Rotor Ring (Curve Slot) - MIATA MX5 REAR (Incl. hardware)-1581026344
  • image_8158
  • image_8158
    MSRP: $395.00
    Now: $375.00
    (You save $20.00 )
    D006-03-321
    Comes with the necessary hardware for each disc.
    Machining: Curve Slot
    Surface: EDP Coating w/cross cut grinding on f
    image_8158
    • image_8157
      Rotor Ring 280x10mm (Curve Slot) for MIATA MX5 REAR (Incl. hardware)-1581026341
      MSRP: $395.00
      Now: $375.00
    • Replacement Rotor Ring 273x10mm for MIATA MX5 REAR (Incl. hardware) Sprots Kit
      MSRP: $410.00
      Now: $389.50
    • 300x12mm Replacement Rotor Rings (Curved Slot) Incl. hardware
      MSRP: $605.00
      Now: $575.00
    • Rotor Ring Replacements (Curve-Slotted) - 340x31mm (Incl. hardware)
      MSRP: $562.10
      Now: $534.00
    • 330x12mm Replacement Rotor Rings (Curved Slot) Incl. hardware
      MSRP: $605.00
      Now: $575.00
