Quick view sku: 90461-211 RB 1pc rotor (Slot) - CORVETTE REAR 88-96 MSRP: $203.50 Now: $193.33 Add to Cart Compare Quick view sku: 90461-213 RB 1pc rotor (Slot) - CORVETTE REAR 88-96-1581024921 MSRP: $203.50 Now: $193.33 Add to Cart Compare Quick view sku: 93241-211 RB 1pc rotor (Slotted) - CORVETTE C5 & C6 (excl. Z51 perf. pkg. 05-08 & Z06 06+) FRONT 97-08 MSRP: $239.80 Now: $227.81 Add to Cart Compare Quick view sku: 93241-213 RB 1pc rotor (Slotted) - CORVETTE C5 & C6 (excl. Z51 perf. pkg. 05-08 & Z06 06+) FRONT 97-08-1581025162 MSRP: $239.80 Now: $227.81 Add to Cart Compare Quick view sku: 93261-211 RB 1pc rotor (Slotted) - CORVETTE C5 & C6 (excl. Z51 perf. pkg. 05-08 & Z06 06+) REAR 97-08 MSRP: $214.50 Now: $203.78 Add to Cart Compare Quick view sku: 93261-513 RB 1pc rotor (Slotted) - CORVETTE C5 & C6 (excl. Z51 perf. pkg. 05-08 & Z06 06+) REAR 97-08-1581025166 MSRP: $214.50 Now: $203.78 Add to Cart Compare Quick view RB 1pc rotor (Slot) - CORVETTE REAR 88-96 Material: Alloyed Gray Iron & Heat treatedMachining: Straight SlotSurface: EDP Coating w/cross cut grinding on friction surface Curved Vane This rotor is upgraded from OE straight MSRP: $203.50 Now: $193.33 Add to Cart Compare Quick view RB 1pc rotor (Slot) - CORVETTE REAR 88-96-1581024921 Material: Alloyed Gray Iron & Heat treatedMachining: Straight SlotSurface: Nickel Plating w/cross cut grinding on friction surface Curved Vane This rotor is upgraded from OE straig MSRP: $203.50 Now: $193.33 Add to Cart Compare Quick view RB 1pc rotor (Slotted) - CORVETTE C5 & C6 (excl. Z51 perf. pkg. 05-08 & Z06 06+) FRONT 97-08 Material: Alloyed Gray Iron & Heat treatedMachining: Straight SlotSurface: EDP Coating w/cross cut grinding on friction surface Curved VaneThis rotor is upgraded from OE straight vane to RB Curved Vane. MSRP: $239.80 Now: $227.81 Add to Cart Compare Quick view RB 1pc rotor (Slotted) - CORVETTE C5 & C6 (excl. Z51 perf. pkg. 05-08 & Z06 06+) FRONT 97-08-1581025162 Material: Alloyed Gray Iron & Heat treatedMachining: Straight SlotSurface: Nickel Plating w/cross cut grinding on friction surface Curved Vane This rotor is upgraded from OE straig MSRP: $239.80 Now: $227.81 Add to Cart Compare Quick view RB 1pc rotor (Slotted) - CORVETTE C5 & C6 (excl. Z51 perf. pkg. 05-08 & Z06 06+) REAR 97-08 Material: Alloyed Gray Iron & Heat treatedMachining: Straight SlotSurface: EDP Coating w/cross cut grinding on friction surface Curved Vane This rotor is upgraded from OE straight MSRP: $214.50 Now: $203.78 Add to Cart Compare Quick view RB 1pc rotor (Slotted) - CORVETTE C5 & C6 (excl. Z51 perf. pkg. 05-08 & Z06 06+) REAR 97-08-1581025166 Material: Alloyed, Gray Iron & Heat treatedMachining: Straight SlotSurface: Nickel Plating w/cross cut grinding on friction surface Curved Vane This rotor is upgraded from OE strai MSRP: $214.50 Now: $203.78 Add to Cart Compare Compare Selected × OK
