    • Cadillac CT5-V Blackwing (2019+) Replacement Rotors (400/370): Front & Rear (P/N 2730 & 2731)
  • Front
  • Rear
  • Cadillac CT5-V Blackwing (2019+) Replacement Rotors (400/370):  Front & Rear (P/N 2730 & 2731) Cadillac CT5-V Blackwing (2019+) Replacement Rotors (400/370):  Front & Rear (P/N 2730 & 2731) Cadillac CT5-V Blackwing (2019+) Replacement Rotors (400/370):  Front & Rear (P/N 2730 & 2731) Front Rear
    MSRP: $3,010.00
    Now: $2,860.00
    (You save $150.00 )
    CAD-IRK-400.370
    • 2 ea Front 2 pc rotors (400x34mm vs. OE 398x36)
    • 2 ea Front caliper spacers to space up to full 400mm)
    • 2 ea Rear 2 pc rotors (370x28mm vs. OE 374x28) - 370mm fits better than OE 374mm w/o developing a lip on rotor edge.
    • 1 set brake pads (optional)
    Kits are designed and made to fit under OE 6 pot front and rear 4 pot calipers with a direct bolt-on installation.
    Weight comparison:
    Feature & Benefits:
    • Weight reduction.
    • Directional rotors for a more efficient cooling.
    • RB patented "Center-Mount" deisgn improves the brake performance and durability.
    • Front: PD1395A
    • Rear: PD592
    • Front: D601-03
    • Rear: D502-09
    A note about the front pads:
    As the pic shown OE pads was a retrofit modification from Camaro's ZL1/1L1 vs RB's modified from standard D1395.
    OE Blackwing pads would not fit RB 2 pcs rotors properly unless the bottom is trimmed.
    RB pads provides a full coverage against the rotor surface for a more efficient performance.
    • RB-CCB Rotor Kit (400/370) for Cadillac CT5-V Blackwing Upgrade Conversion From Stock Iron Rotors Fits OE Calipers & Spindles (P/N 2R69 & 2R70) OE pads
      Now: $12,350.00
    • McLaren MP4-12C Rotor Kit (370/350) for Stock Iron Rotor Replacement Front & Rear (P/N 2450 & 2451) front pad
      Now: $3,252.50
    • RB 2pc Rotor Kit (370/365) for Camaro ZL1 G5/Cadillac CTS-V (V2 09-15)/Karma Front & Rear (P/N 2160 & 2140) RB 2pc Rotor Kit (370/365) for Camaro ZL1 G5/Cadillac CTS-V (V2 09-15)/Karma Front & Rear (P/N 2160 & 2140)
      MSRP: $2,878.70
      Now: $2,734.77
    • Front brake rb front 2 pc rotor
      Tesla Cybertruck Brake Rotor Replacement - Front & Rear (P/N 2721 & 2722)
      MSRP: $2,620.00
      Now: $2,489.00
    • RB 2pc Rotor Kit (374/374) for RAM TRX (2019+) Stock Replacement Front & Rear (P/N 2701 & 2702) Front rotor wt
      MSRP: $2,700.00
      Now: $2,565.00
