Quick view 2 ea. RB Light Wt Rotor Hat for Corvette ZR1/C7 Rear CCM Rotors (390mm) (Incl. Harware Kit) MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view [PD-ZR1-397] RB (XT970) Track Pads for Iron Rotor Conversion from CCB - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren etc. FRONT & REAR: (PD1395/PD1165) MSRP: $690.00 Was: Now: $655.50 Choose Options Compare Quick view RB 2pc Rotor Kit (390/390) for Corvette C7 ( CCM to Iron Conversion) (P/N 2242 & 2368) MSRP: $3,400.00 Was: Now: $2,990.00 Choose Options Compare Quick view RB-CCB Disc (390x32x66mm) - Price per pair. MSRP: $4,490.00 Was: Now: $4,266.00 Choose Options Compare Quick view RB-CCB Disc (394x36x89mm) - Price per pair. MSRP: $4,850.00 Was: Now: $4,607.50 Choose Options Compare Quick view RB-CCB Disc (410x36mm) - Price per pair. MSRP: $5,455.00 Was: Now: $5,180.00 Add to Cart Compare Quick view RB-CCB Rotor Kit (394/390) for Corvette C7 Replacement or Upgrade from OE's Chopped Carbon Fiber CCB Rotors (P/N 2C01 & 2C52) MSRP: $12,527.36 Was: Now: $11,900.99 Choose Options Compare Quick view RB-CCB System Kit (394/390) for Corvette C7 (P/N 2C01-C7-K & 2C52-K) MSRP: $16,737.88 Was: Now: $15,900.99 Choose Options Compare Quick view 2 ea. RB Light Wt Rotor Hat for Corvette ZR1/C7 Rear CCM Rotors (390mm) (Incl. Harware Kit) These light weight composite hats are fully compatible with OE Emergency brake. OE Stainless Steel Hat: RB Composite Hat (Aluminum hat w/iron liner): MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) Installation Note: For Ford GT350 6 pot calipers installation it requires a hardware kit (included on request) to create proper tension from the hold down spring to the brake pads to avoid rattling. Brembo OE ZR1 brake pad dimension flow as seen on... MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view [PD-ZR1-397] RB (XT970) Track Pads for Iron Rotor Conversion from CCB - Corvette ZR1, Camaro Z28, Ferrari F458, McLaren etc. FRONT & REAR: (PD1395/PD1165) This brake pad set is made with RB XT970 compound for iron rotors that are duly converted from factory CCM rotors. If you have original CCB rotors and looking for brake pad replacement you should order our ST600 compounds MSRP: $690.00 Was: Now: $655.50 Choose Options Compare Quick view RB 2pc Rotor Kit (390/390) for Corvette C7 ( CCM to Iron Conversion) (P/N 2242 & 2368) Installation notes: This rotor kit is specially made for converting original CCM to iron rotors with a direct & 100% bolt on installation. No change to your OE calipers as our rotors are made with the same dimensions as the original CCM rotors, not... MSRP: $3,400.00 Was: Now: $2,990.00 Choose Options Compare Quick view RB-CCB Disc (390x32x66mm) - Price per pair. Discs are made for a direct replacement to OE/Brembo with long carbon fibers. See tech info. MSRP: $4,490.00 Was: Now: $4,266.00 Choose Options Compare Quick view RB-CCB Disc (394x36x89mm) - Price per pair. Discs are made for a direct replacement to OE/Brembo with long carbon fibers. See tech info. MSRP: $4,850.00 Was: Now: $4,607.50 Choose Options Compare Quick view RB-CCB Disc (410x36mm) - Price per pair. MSRP: $5,455.00 Was: Now: $5,180.00 Add to Cart Compare Quick view RB-CCB Rotor Kit (394/390) for Corvette C7 Replacement or Upgrade from OE's Chopped Carbon Fiber CCB Rotors (P/N 2C01 & 2C52) The rotor kit is bundled with our ST600 high metallic brake agressive street pads (not for tracks) specially developed for carbon ceramic rotors. Performance characteristics is comparable to Pagid RSC1 and OE Brembo. Consistent COF... MSRP: $12,527.36 Was: Now: $11,900.99 Choose Options Compare Quick view RB-CCB System Kit (394/390) for Corvette C7 (P/N 2C01-C7-K & 2C52-K) Kit contains: 2 ea. RB 6-piston calipers 2 ea. Front caliper adaptors (AD603-C7) 2 ea. RB 4-piston calipers 2 ea. Rear caliper adaptors 2 ea. Front CCB rotors 2 ea. Rear CCB rotors 1 car set CCB brake pads MSRP: $16,737.88 Was: Now: $15,900.99 Choose Options Compare Compare Selected × OK
