Quick view [PD1781.PD1785] RB Bundle Street Pads for Audi C7 RS6/7 Front & Rear w/ccb Conversion Upgrade MSRP: $1,343.00 Was: Now: $758.00 Choose Options Compare Quick view RB 4 piston Calipers w/ePB & CCB Rotor Kit (370x30mm) for Audi C7/C8 Rear CCB Replacement (or Iron Conversion Upgrade) from OE 1 Pot Floating Calipers MSRP: $6,840.00 Was: Now: $6,499.00 Choose Options Compare Quick view RB-CCB Rotor Conversion Kit (390x36mm) for Audi C7 (RS6/RS7) and ALL C7 Models (A/S/RS/Q) CCB Upgrade Conversion from Iron Rotors (P/N: 2R76) MSRP: $6,590.00 Was: Now: $6,260.00 Pre-Order Now Compare Quick view RB-CCB Rotor Kit (420/370) for Audi C7 (12-18) RS6/7 CCB Replacement (P/N 2C95 & 2R10) MSRP: $13,500.00 Was: Now: $12,825.00 Pre-Order Now Compare Quick view [PD1781.PD1785] RB Bundle Street Pads for Audi C7 RS6/7 Front & Rear w/ccb Conversion Upgrade Installation Note: The wear sensor is located on the side instead of middle like OE. Brake pad characteristics: Consistent COF (Coefficient of Friction) Wider range of environmental temperature Excellent modulation Highly durable MSRP: $1,343.00 Was: Now: $758.00 Choose Options Compare Quick view RB 4 piston Calipers w/ePB & CCB Rotor Kit (370x30mm) for Audi C7/C8 Rear CCB Replacement (or Iron Conversion Upgrade) from OE 1 Pot Floating Calipers Kit includes 2 ea Rear CCB rotors (370x30mm) 2 ea RB 4 piston calipers w/integrated ePB (Replacing OE 1 pot floating calipers) 2 ea caliper adaptors 1 set ccb brake pads Replacement rotor rings: Rear: CR06 Replacement brake pads: Rear:... MSRP: $6,840.00 Was: Now: $6,499.00 Choose Options Compare Quick view RB-CCB Rotor Conversion Kit (390x36mm) for Audi C7 (RS6/RS7) and ALL C7 Models (A/S/RS/Q) CCB Upgrade Conversion from Iron Rotors (P/N: 2R76) This CCB rotor kit is designed for Audi C7 RS6/RS7 conversion upgrade to ccb with a direct swap to stock iron rotors. It also fit ALL Audi C7 models from 2012-2018 Kit includes: 2 ea front CCB rotors (390x36mm) 1 set ccb pads Rear rotor kit options: 2... MSRP: $6,590.00 Was: Now: $6,260.00 Pre-Order Now Compare Quick view RB-CCB Rotor Kit (420/370) for Audi C7 (12-18) RS6/7 CCB Replacement (P/N 2C95 & 2R10) Kit includes: 2 ea front CCB rotors (420x36 vs. OE 420x38mm) 2 ea rear CCB rotors (370x30mm) 1 car set of brake pads (Optional) Replacement brake pads: Front: PD1781(PD1530) Rear: PD1785 MSRP: $13,500.00 Was: Now: $12,825.00 Pre-Order Now Compare Compare Selected × OK
