    • RB 2Pc Rotor Kit (390x36/380x32) for Corvette C6 ZR1 / Z06 Carbon Edition w/CCM Rotors Conversion to Iron Rotos Front & Rear (P/N 2242 & 2243)
  • Front
  • Rear
  • RB 2Pc Rotor Kit (390x36/380x32) for Corvette C6 ZR1 / Z06 Carbon Edition w/CCM  Rotors Conversion to Iron Rotos Front & Rear (P/N 2242 & 2243) Front Rear
    MSRP: $3,145.00
    Now: $2,988.00
    (You save $157.00 )
    C6-IRK-01
    Kit Contents:
    • 2 ea Front 2pc rotors (390x36 vs. 394x36mm). Our rotors fits better than OE 394mm that eliminate the undesirable rusty lips.
    • 2 ea Rear e pc rotors (380x32 vs. 380x34mm)
    • 1 set brake pads made for iron rotors - Optional
    Feature & benefit:
    • Rotors are made for 100% bolt-on installation
    • Seamlessly converting fragile OE rotors to durable, economical iron rotors
    • Rear rotors are made with composite hats (light weight aluminum shell with iron sleeve insert) for both ccm or iron rotors - Fully compatible with OE drum brake for emergency & parking.
    • Unlike some other verders, the hat are machined from aluminum which will have the rear drum destroyed after parking brake is applied.
    RB light weight composite hat: Saves 4.8 lbs per hat.
    OE Stainless steel hat:
    • Front: PD1395
    • Rear: PD1001
    • Front: D602-01
    • Rear: D601-08
    Corvette forum review:
    [ZR1] Ceramic to RB steel rotors conversion
    • RB 2pc Rotor Kit (390/390) for Corvette C7 ( CCM to Iron Conversion) (P/N 2242 & 2368) RB 2pc Rotor Kit (390/390) for Corvette C7 ( CCM to Iron Conversion) (P/N 2242 & 2368)
      MSRP: $3,400.00
      Now: $2,990.00
    • Corvette 6/4 Pot Caliper Brake Kit (390x36/380x30) for Corvette C5/C6 Upgrade to C6 CCM Rotor Size (P/N 2242-K & 2243-K) Front Kit
      MSRP: $7,560.00
      Now: $7,182.00
    • RB 2pc Rotor Kit (400/380) for Corvette C8 Z06 CCB Downgrade to Iron Conversion Front & Rear (P/N 2748 & 2749)
      MSRP: $3,120.00
      Now: $2,964.00
    • RB 2pc Rotor Kit (370/380) for Corvette C8 Z06 Front & Rear (P/N 2160 & 2749)
      MSRP: $2,850.00
      Now: $2,699.00
    • 2 ea. RB Light Wt Rotor Hat for Corvette C6 ZR1 Rear CCM Rotors (380mm) (Incl. hardware kit) 2 ea. RB Light Wt Rotor Hat for Corvette C6 ZR1 Rear CCM Rotors (380mm) (Incl. hardware kit)
      MSRP: $1,936.00
      Now: $1,839.20
