RB CCB Bed-in Procedure: https://racingbrake.com/ccb-break-in-procedure/
Carbon Ceramic rotors, unlike iron rotors, require longer bed-in time before developing an optimal performance. Less bed-in or over bed-in will affect the braking performance.
Initial Bed-In: (System warm up & engage rotors and pads together as one unit)
Heavy Bed-In: (Friction layer formed between rotors and pads)
Cool off Bed-In: (System cool down)
When you finish all above steps, the rotor surface should look shinny which is an indication that the bed-in procedure is successfully completed. If not due to variable setups and road conditions, repeat the above steps.
