    • RB 2Pc Rotor kit (380x32/370x26) for M3/M4 F80 Stock Replacement (P/N 2384 & 2385)
  • Front caliper
  • Front OE pad
  • Rear caliper
  • Rear OE pad
  • RB 2Pc Rotor kit (380x32/370x26) for M3/M4 F80 Stock Replacement (P/N 2384 & 2385) Front caliper Front OE pad Rear caliper Rear OE pad
    MSRP: $2,650.00
    Now: $2,495.00
    (You save $155.00 )
    BMW-IRK-380.370-F80
    Kit contains:
    • 2 ea. front RB 2 pc rotors (380x32 vs. OE 380x30)
    • 2 ea. rear RB 2 pc rotors (370x26 vs. OE 370x24)
    • Brake pads are not available.
    Note: Our rotors are made 2mm thicker than OE (both front and rear) for extra thermal capacities, and are certified to they can fit under OE calipers but better with less clearance (see below calculation) w/o any concern or issues as long as the pads are no thicker than OE.
    OE pad thickness:
    • Front: 17.5mm
    • Rear: 17.4mm
    Calculating allowable rotor thickness:
    • Front caliper pad gap = 69.3-(17.5x2=35) = 34.3mm for rotor (32mm OK)
    • Rear caliper pad gap = 61.86-(17.4x2=34.8) = 27.1mm for rotor (26mm OK)
    • Front: D501-01
    • Rear: D502-02
    • RB 2pc Rotor Kit (374x36/370x26) for BMW M5 E60 Stock Replacement (P/N 2327 & 2328) Front rotor dimensions
      MSRP: $2,640.00
      Now: $2,508.00
    • RB 2Pc Rotor kit (400x38/380x28) for M3/M4 F80 with Gold Calipers: CCB to Iron Conversion (P/N 2490 & 2524)
      MSRP: $3,430.00
      Now: $3,090.00
    • RB 2pc Rotor Kit (400x34) for Lexus LC500 Front Stock Replacement (P/N: 2469) RB 2pc Rotor Kit (400x34) for Lexus LC500 Front Stock Replacement (P/N: 2469)
      MSRP: $1,400.00
      Now: $1,330.00
    • RB-CCB Rotor Kit (400/380) for BMW M3/M4 F80 CCB Rotor Replacement (PN 2R13 & 2C14)
      MSRP: $13,600.00
      Now: $12,920.00
    • RB 2pc Rotor Kit (374x36/370x24) for BMW M Sports Stock Replacement (P/N 2663 & 2698) front rotor
      MSRP: $2,800.00
      Now: $2,660.00
