    • RB-CCB Rotor kit (394/380) for BMW F90 M5/M6/M8 CCB Conversion Upgrade from Iron (PN: 2R26 & 2R27)
  • rear rotor
  • rear 4 pot ePB caliper (optional)
  • RB-CCB Rotor kit (394/380) for BMW F90 M5/M6/M8 CCB Conversion Upgrade from Iron (PN: 2R26 & 2R27) rear rotor rear 4 pot ePB caliper (optional)
    MSRP: $12,925.00
    Now: $12,278.00
    (You save $647.00 )
    (1 review) Write a Review
    BMW-CRK-M5.F90
    This CCB rotor kit is designed and made for M5/M6 F90 iron rotor to ccb conversion upgrade.
    • 100% direct bolt-on installation.
    • No modification
    • RB discs are made of long carbon fibers stronger and more durable than OE ccb rotors' chopped carbon fibers.
    • Lower operating & maintenance cost.
    • Add pads to option for RB ST600 ccb pads, or keep using stock ccb pads.
    • Requires 20" wheels to install.
    Weight comparison:
    • 2 ea RB CCB rotors (394x36mm vs. 395x36)
    • 2 ea RB CCB rotors (380x28mm)
    • 1 set of ccb pads (Optional)
    Replacement ccb pads:
    • Front: PD2155-360
    • Rear: PD2059-360
    • 5
      Posted by Rafe on Jul 4th 2025
      Installed the RB carbon-ceramic rotor and pad set on my F90 M5 and couldn’t be more impressed. The fitment was perfect, and braking performance is a major upgrade — powerful, consistent, and completely fade-free under hard use. What really surprised me is how much the car improved outside of braking: cornering feels sharper and more planted, especially in quick transitions. I didn’t expect brake rotors to influence handling this much, but the reduced weight is clearly making a difference. Also — zero squeaking, and brake dust is virtually nonexistent. After ~1,000 miles, they’ve bedded in beautifully and feel better than day one. Easily one of the most confidence-inspiring mods I’ve done. Highly recommended.
    • RB-CCB Rotor kit (400/380) for BMW F90 M5/M6/M8 CCB Replacement (PN: 2R89 & 2R27) RB-CCB Rotor kit (400/380) for BMW F90 M5/M6/M8 CCB Replacement (PN: 2R89 & 2R27)
      MSRP: $13,500.00
      Now: $12,825.00
    • RB-CCB Rotor Kit (394/380) for Corvette C8 Z06 Iron to CCB Conversion Upgrade (PN 2C38 & 2R32) front rotor 394x36
      MSRP: $12,300.00
      Now: $11,700.00
    • RB-CCB Rotor Kit (370/380) for Corvette C8 Z06 Iron to CCB Conversion Upgrade (PN 2R77 & 2R32) Rear
      MSRP: $11,200.00
      Now: $10,785.00
    • RB-CCB Rotor Kit (380/380) for BMW M2/M3/M4 F80 Conversion Upgrade from Iron Rotors (PN 2C94 & 2C80)
      MSRP: $12,150.00
      Now: $11,530.00
    • RB 2Pc Rotor kit (400/380) for M5 F90, M3/M4, M8, G8x CCB to Iron Rotor Conversion (P/N 2725 & 2645) RB 2Pc Rotor kit (400/380) for M5 F90, M3/M4, M8, G8x CCB to Iron Rotor Conversion (P/N 2725 & 2645)
      MSRP: $3,320.00
      Now: $3,155.00
