    • RB-CCB Brake Kit (420/370) for ALL C8 (2019+) A/S/RSQ/SQ Models Converting OE Iron to CCB Upgrade, Front & Rear (P/N: 2R54 & 2CR10)
  • front ccb
  • rear ccb
  • OE front caliper - 27.6 lbs
  • rear bbk
  • OE front rotor - 46.7 lbs
  • front ccb rear ccb OE front caliper - 27.6 lbs rear bbk OE front rotor - 46.7 lbs
    MSRP: $14,000.00
    Was: $13,300.00
    Now: $12,630.00
    (You save $1,370.00 )
    AU-CRK-C8-420.370
    This ccb rotor kit is offered for RS6/RS7 converting from stock iron rotors; other C8 models owners must acquire Akebono 10 pot calipers, or add 6 pot calipers at option to install the kit.
    • 2 ea front CCB rotors (420x40mm)
    • 2 ea rear CCB rotors (370x30mm)
    • 1 set brake pads - Optional
    Feature & benefit:
    • Direct bolt-on installation.
    • Retain your OE calipers & pad shapes.
    • Replacing bulky and insanely heavy OE iron rotors.
    • Eliminate brake dust.
    • Improve driving comfort.
    • Save other components wear/tear replacement due to unsprung rotor wt reduction.
    Weight comparison:
    Replacement brake pads: https://racingbrake.com/pd1899-pd1895-360/
    front ccb
    • front kit installed Front Kit Bench Test 2
      RB-CCB Brake Kit (400/370) for ALL C8 (2019+) A/S/RS/Q/SQ Models Converting OE Iron to CCB Upgrade, Front & Rear (P/N: 2R75 & 2R10)
      MSRP: $6,800.00
      Now: $6,460.00
      MSRP: $14,348.41
      Now: $13,630.00
    • RB-CCB Rotor Kit (370/380) for Corvette C8 Z06 Iron to CCB Conversion Upgrade (PN 2R77 & 2R32) Rear
      MSRP: $11,200.00
      Now: $10,785.00
      MSRP: $10,500.00
      Now: $9,975.00
    • RB-CCB Rotor Kit (420/370) for Audi C7 (12-18) RS6/7 CCB Replacement (P/N 2C95 & 2R10) RB-CCB Rotor Kit (420/370) for Audi C7 (12-18) RS6/7 CCB Replacement (P/N 2C95 & 2R10)
      MSRP: $13,500.00
      Now: $12,825.00
