    • RB-CCB Brake Kit (400/370) for ALL C8 (2019+) A/S/RS/Q/SQ Models Converting OE Iron to CCB Upgrade, Front & Rear (P/N: 2R75 & 2R10)
  • Front Full Kit
  • Front Kit Bench Test 2
  • front kit installed
  • rear kit installed
  • ccb car kit installed
  • ccb rotor kit
  • Front wt
  • Rear wt
  • Rear ePB
  • front oe brake
  • front oe rotor
  • rear oe rotor
  • rear oe brake
  • rear ccb kit
  • Front Full Kit Front Kit Bench Test 2 Front Kit Bench Test front kit installed rear kit installed ccb car kit installed ccb rotor kit Front wt Rear wt Rear ePB front oe brake front oe rotor rear oe rotor rear oe brake rear ccb kit
    MSRP: $6,800.00
    Now: $6,460.00
    (You save $340.00 )
    (1 review) Write a Review
    AU-CRK-400.370
    • 2 ea front CCB rotors (400x38mm)
    • 2 ea rear CCB bbk (370x30mm vs. OE 350x28)
    • 2 ea Brembo 6 pot calipers (Optional) - Rebuilt/tested/warranted by RB
      • Calipers are refurbished & rebuilt by RB.
      • Newly powder coated in red color
      • New seals & boots
      • Pistons are inspected to make sure they are in good & working condition
      • Calipers includes adaptors & ccb brake pads
    • 2 ea RB 4 pot ePB calipers (Optional) - Replacing OE 1 pot floating calipers
    • 2 ea rear caliper adaptors
    • 1 car (axle) set ccb brake pads - As selected
    https://racingbrake.com/pd1781-pd1785-360/
    Front 6 pot calipers comparison:
    BA61 - Audi C7 (2013-2018) S6 Brembo 6 pot caliper for Iron Rotors.
    Before refurbishing:
    After powder coating:
    eTron front 6-pot
    Feature & benefits:
    • Retain stock caliper and pad.
    • Direct rotor and pad swap installation.
    • Replacing stock heavy iron rotors with light weight CCB rotors - Increase mileage & reduce the maintenance downtime/cost.
    Installation requires 20"+ wheels
    Learn why RB-CCB rotors perform better and last longer than OE/Brembo rotors.
    https://racingbrake.com/tech-info/
    Front Full Kit
    • 5
      CCB Brake Kit Performance
      Posted by Christopher Starnes on Aug 27th 2025
      I have three sets of RB's CCB brakes. This is the best of the three as it upgrades the rear caliper to 4 piston. The performance of these setups is very similar. Linear, unfading, progression. I have never felt like I had this much modulation control while hard braking. I KNOW where these kits will lock up and I know I can modulate that process without difficulty. Other CCB I have driven have a really strong initial response but then the feedback at the pedal becomes numb. I don't feel like I control the intensity of braking as much as with Racing Brakes design. I will be putting these systems on all my future rides. Currently with Audi SQ7, Nissan GTR and Tesla S Plaid.
    • SALE
      front ccb rear ccb
      RB-CCB Brake Kit (420/370) for ALL C8 (2019+) A/S/RSQ/SQ Models Converting OE Iron to CCB Upgrade, Front & Rear (P/N: 2R54 & 2CR10)
      MSRP: $14,000.00
      Was: $13,300.00
      Now: $12,630.00
    • ccb rotor kit front
      RB-CCB Rotor Conversion Kit (390x36mm) for Audi C7 (RS6/RS7) and ALL C7 Models (A/S/RS/Q) CCB Upgrade Conversion from Iron Rotors (P/N: 2R76)
      MSRP: $6,590.00
      Now: $6,260.00
    • RB-CCB Rotor Kit (370/380) for Corvette C8 Z06 Iron to CCB Conversion Upgrade (PN 2R77 & 2R32) Rear
      MSRP: $11,200.00
      Now: $10,785.00
    • RB-CCB Rotor Kit (420/370) for Audi C7 (12-18) RS6/7 CCB Replacement (P/N 2C95 & 2R10) RB-CCB Rotor Kit (420/370) for Audi C7 (12-18) RS6/7 CCB Replacement (P/N 2C95 & 2R10)
      MSRP: $13,500.00
      Now: $12,825.00
      MSRP: $14,348.41
      Now: $13,630.00
