    • RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DB9, Vanquish, Virage, Vantage V12S; Front and Rear (P/N 2409 & 2410)
  • Front rotor
  • Rear Rotor
  • Front Pad
  • Rear Pad
  • RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DB9, Vanquish, Virage, Vantage V12S;  Front and Rear (P/N 2409 & 2410) RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DB9, Vanquish, Virage, Vantage V12S;  Front and Rear (P/N 2409 & 2410) RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DB9, Vanquish, Virage, Vantage V12S;  Front and Rear (P/N 2409 & 2410) Front rotor Rear Rotor Front Pad Rear Pad
    MSRP: $3,500.00
    Now: $3,325.00
    (You save $175.00 )
    AM-IRK-394.360
    This rotor and pad kit is specially made for converting OE CCB to Iron rotors with a 100% bolt on installation. Not only it can eliminate that annoying squeaks from OE CCB rotors but lower your maintenance & replacement cost.
    Please carefully verify your model/year before ordering. If you have late model (DB11 2017+) you should order this kit (w/128mm Bolt hole circle)
    Forum reviews:
    BG Stop Squeal: Finally a cure for Aston Martin Brake Squeal issues
    Converted from carbon ceramic to steel rotors. No more squeaking!!!!
    Kit contents:
    • 2 Front RB Iron Rotors
    • 2 Rear RB Iron Rotors
    • 1 set of front pads
    • 1 set of rear pads
    Replacement rotor ring:
    Front: D601-09
    Rear: D501-05
    Brake pads included in the kit and listed below are for street driving, for off-street applications please contact us for further details.
    Front: PD1395B
    Rear: PD1001
    • Carbon Ceramic Rotor Kit (394/360) for Aston Martin DB9, Vanquish, Vantage V12S CCB Rotor Replacement, Front & Rear (P/N 2C06 & 2C97) Carbon Ceramic Rotor Kit (394/360) for Aston Martin DB9, Vanquish, Vantage V12S CCB Rotor Replacement, Front & Rear (P/N 2C06 & 2C97)
      MSRP: $13,310.00
      Now: $12,644.50
    • RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DBS 11+ (2017+ w/128mm Bolt Hole Circle) Front and Rear (P/N 2699 & 2700) RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DBS 11+ (2017+ w/128mm Bolt Hole Circle) Front and Rear (P/N 2699 & 2700)
      MSRP: $3,800.00
      Now: $3,610.00
    • [PD-AM-360] RB Pads Kit for CCM Rotors - Aston Martin DB9 04-16; Vanquish, 12-18; Vantage V12S 13+ Front and Rear (PD1395B & PD1165) - ST600 [PD-AM-360] RB Pads Kit for CCM Rotors - Aston Martin DB9 04-16; Vanquish, 12-18; Vantage V12S 13+ Front and Rear (PD1395B & PD1165) - ST600
      Now: $0.00
