    • RB-CCB Rotors (400/360) for Alfa Romeo Giulia Quadrifoglio 2017+ CCM Rotor Replacement Front and Rear (P/N 2R38 & 2R39)
  • Front rotor
  • Rear rotor
  • Front setup
  • Rear setup
  • Front pad
  • Rear pad
  • RB-CCB Rotors (400/360) for Alfa Romeo Giulia Quadrifoglio 2017+ CCM Rotor Replacement Front and Rear (P/N 2R38 & 2R39) Front rotor Rear rotor Front setup Rear setup Front pad Rear pad
    MSRP: $13,326.00
    Now: $12,660.00
    (You save $666.00 )
    ALF-CRK-400.360
    • 2 ea front CCM rotors (400x36 vs. OE 390x36)
    • 2 ea front caliper spacer kits (for larger rotors)
    • 2 ea rear CCM rotors (360x26 vs. OE 360x28)
    • 1 car set CCB brake pads (optional)
    • This CCB rotor kit is exclusively made for Quadrifoglio with CCB for a direct upgrade replacement.
    • Easy installation w/o requiring any modifications.
    • Re-use OE front 6 pot and rear 4 pot CCB calipers (not included)
    • Larger front rotors provide extra thermal capacity so you can run brake at lower temperature than stock size.
    Features and benefits:
    • Rotors are made with long carbon fibers (Vs. OE chopped fibers) with directional cooling vanes, so they are stronger and more durable and can disippate heat more efficiently than OE.
    • Discs are re-furbishiable.
    • Front: CR14
    • Rear: CR31
    • Front/Rear: PD-ARQ-360
    OE CCB 390x36/360x28 15 12 27 54
    RB CCB 400x36/360x26 16* 10 26 52
    Wt Saving       2
    *Oversized (400mm vs. OE 390mm)
    Compared ours to OE CCB replacement cost:
    Brake pads:
    • Front pads $1,799.99:
    • Rear pads $1,699.99:
    Brake rotors:
    • Front rotor: (390x36) 6.799,00 EUR
    • Rear rotor: (360x28) 6.799,00 EUR
    • RB 2pc Rotor Kit (390/360) for Alfa Romeo Giulia Quadrifoglio 2017+ CCM to Iron Conversion (P/N 2672 & 2673) RB 2pc Rotor Kit (390/360) for Alfa Romeo Giulia Quadrifoglio 2017+ CCM to Iron Conversion (P/N 2672 & 2673)
      MSRP: $3,600.00
      Now: $3,420.00
    • [PD2043-360] RB  Brake Pads for CCM Rotors - Alfa Romeo Giulia/Stelvio 2.9L Quadrifoglio Upgrade Conversion to CCM Rotors - Rear [PD2043-360] RB  Brake Pads for CCM Rotors - Alfa Romeo Giulia/Stelvio 2.9L Quadrifoglio Upgrade Conversion to CCM Rotors - Rear
      MSRP: $345.00
      Now: $327.60
    • [PD1666-360] ST600 Brake Pad for RB 6 Pot & Alfa Romeo Giulia Quadrifoglio Converting to CCB Rotors [PD1666-360] ST600 Brake Pad for RB 6 Pot & Alfa Romeo Giulia Quadrifoglio Converting to CCB Rotors
      MSRP: $638.00
      Now: $606.10
    • RB 2Pc Rotor Kit (360/350) for Alfa Romeo GiuliaStelvio 2.9L Quadrifoglio Stock Replacement Front & Rear (P/N 2674 & 2675) front
      MSRP: $2,946.00
      Now: $2,799.00
    • RB Big Rotor Kit (380x32mm) for Alfa Romeo Giulia/Stelvio & QUADRIFOGLIO Front  (P/N: 2694-K/2675-K) Front BBK rotor
      MSRP: $1,530.00
      Now: $1,453.50
