    • RB-CCB Rotor Kit (380/350) for Alfa Romeo Giulia/Stelvio 2.9L Quadrifoglio Upgrade Conversion to ccb Rotors; Front & Rear (P/N 2R65 & 2R66); This conversion will make your new brake to have the same Rotors as Porsche 997.2 GT3 PCCB
  • front rotor
  • rear rotor
  • RB-CCB Rotor Kit (380/350) for Alfa Romeo Giulia/Stelvio 2.9L Quadrifoglio Upgrade Conversion to ccb Rotors; Front & Rear (P/N 2R65 & 2R66); This conversion will make your new brake to have the same Rotors as Porsche 997.2 GT3 PCCB front rotor RB-CCB Rotor Kit (380/350) for Alfa Romeo Giulia/Stelvio 2.9L Quadrifoglio Upgrade Conversion to ccb Rotors; Front & Rear (P/N 2R65 & 2R66); This conversion will make your new brake to have the same Rotors as Porsche 997.2 GT3 PCCB rear rotor RB-CCB Rotor Kit (380/350) for Alfa Romeo Giulia/Stelvio 2.9L Quadrifoglio Upgrade Conversion to ccb Rotors; Front & Rear (P/N 2R65 & 2R66); This conversion will make your new brake to have the same Rotors as Porsche 997.2 GT3 PCCB
    MSRP: $11,500.00
    Now: $10,950.00
    (You save $550.00 )
    ALF-CRK-380.350
    This rotor kit is specially designed for a direct conversion upgrade from iron to CCB rotors for Giulia & Stelvio Quadrifoglio equipped with 6/4 pot calipers and a separate parking brake on the rear only. It's designed for an easy "rotor and pad swap" installation w/o requiring any modifications.
    If you have 2.0L (Non-Quadrifoglio) model (below) you must replace your rear spindle and calipers as shown in the above picture in order to install the rear CCB rotor kit.
    Please contact us if you require any further assistance in the rear spindle/brake swap.
    • 2 ea front CCM rotors (380x34 vs. OE 360x32)
    • 2 ea rear CCM rotors (350x28=Stock)
    • 1 set front caliper spacers (for installing the big rotors)
    • 1 car set CCB brake pads (optional)
    Features and benefits:
    1. Rotors are made for a 100% direct bolt-on installation (Quadrifoglio models only), they will fit OE 6 pot front and 4 pot rear calipers, and the parking brake w/o any modification.
    2. Unlike converting to OE CCB which requires to swap the rear spindle for 360x28 rotor, our rear CCB rotors are made 100% compatible to your existing iron brake so no spindle or calipers swap is required.
    3. Save time and money in acquiring and swapping spindle/calipers.
    4. Easy installation - Easier than replacing stock iron rotors because of light weight.
    5. Stay in stock configuration, swap ccb and iron rotors back and forth as you need.
    6. Lower your maintenance down time and replacement cost.
    7. More brake pad contact surface. (65mm pad depth vs oe 55mm)
    • Front pads: PD1666-360
    • Rear pads: PD2043-360
    *Please note our front pads do not have a provision for OE (pin type) wear sensor.
    Compared to OE CCB replacement cost:
    Brake pads:
    • Front pads $3,400:
    • Rear pads $2,767:
    Brake rotors:
    • Front rotor: (390x36) 6.199,00 EUR
    • Rear rotor: (360x28) 6.999,00 EUR
    How to disable the wear sensor signal:
    Following procedures will close the circuit thus eliminate "warning" signal resulting from pad wear (when the pad is worn down so the sensor is contacting with the rotor & the circuit is broken (open).
    We recommend periodic visual inspection for a more reliable feedback.
    1. Detach the cable from the brake pad and strip the shield to expose the copper strands (2)
    2. Twist 2 strands together.
    3. Bend the twisted strands.
    4. Replace the heat shield sleeve (black) back.
    • [PD2043-360] RB  Brake Pads for CCM Rotors - Alfa Romeo Giulia/Stelvio 2.9L Quadrifoglio Upgrade Conversion to CCM Rotors - Rear [PD2043-360] RB  Brake Pads for CCM Rotors - Alfa Romeo Giulia/Stelvio 2.9L Quadrifoglio Upgrade Conversion to CCM Rotors - Rear
      MSRP: $345.00
      Now: $327.60
    • RB-CCB Rotor Kit (380/350) for Porsche 997.2 GT3 Pccb Replacement (P/N 2C12 & 2C25) front dimensions
      MSRP: $12,600.00
      Now: $11,970.00
      MSRP: $10,500.00
      Now: $9,975.00
    • RB Rotor Kit (380/350) for Porsche 997.2 GT3/RS Pccb to Iron Conversion (P/N 2361 & 2180) RB Rotor Kit (380/350) for Porsche 997.2 GT3/RS Pccb to Iron Conversion (P/N 2361 & 2180)
      MSRP: $3,311.00
      Now: $3,145.45
    • RB-CCB Rotors (400/360) for Alfa Romeo Giulia Quadrifoglio 2017+ CCM Rotor Replacement Front and Rear (P/N 2R38 & 2R39) Front rotor
      MSRP: $13,326.00
      Now: $12,660.00
