        • CROSS OVER TUBE
        • MIS FITTINGS
      • All ACCESSORIES
      • CROSS OVER TUBE
      • MIS FITTINGS
        • CROSS OVER TUBE
        • MIS FITTINGS
    • OE Caliper BBK (410/390) for Tesla S/X Plaid Front and Rear (P/N 2681 & 2643)
      • All ACCESSORIES
      • CROSS OVER TUBE
      • MIS FITTINGS
  • Kit contents
  • Front Kit
  • Front 410mm
  • Front 410mm wt
  • Rear 390mm
  • Rear 390mm wt
  • Rear 410mm
  • Rear 410mm wt
  • Pad comparison
  • Front OE 21"
  • Front OE 21"
  • Rear OE 21"
  • Rear OE 21"
  • Kit contents Front Kit Front 410mm Front 410mm wt Rear 390mm Rear 390mm wt Rear 410mm Rear 410mm wt Pad comparison Front OE 21" Front OE 21" Rear OE 21" Rear OE 21"
    MSRP: $4,125.00
    Now: $3,920.00
    (You save $205.00 )
    TES-IRK-410.390
    To assure an optimal performance:
    Brake pad deduct is not available at this time.
    • 2 ea - Front oversized 2pc rotors 410x33mm vs. stock 380x32 (Plaid S) or 390x32 (Plaid X)
    • 1 set - Front caliper spacer and hardware kit
    • 2 ea - Rear oversized 2pc rotors 390x28mm or 410x30mm vs. stock 365x28 - Select at option
    • 1 set - Rear caliper bracket and hardware kit
    • 1 car set - Brake pads
    • 1 car set - Rotor retaining screws (Missing from OE rotors)
    • 1 car set - Stainless steel braided brake line (optional)
    Design Highlights
    The brake system is designed and developed by RB with decades of experience in high performance brake systems to bring you the best value brake upgrade for your 2021+ Plaid S/X & Long Range.
    The front big rotor has a wider annulus (76mm) to accommodate the larger (65mm depth) pad (see below) which can substantially increase the overall thermal capacity to lower the braking temperature - A fundamental, direct, and effective solution to overheating on the track (over changing the brake fluid, and installing a cooling kit etc.).
    A real BBK that can help you handle your Plaid on the track with ease and confidence, so you can focus on improving your track skills and shortening your lap time.  No more worrying about your brakes.
    Front 410mm Kit fits 21" OE wheels w/14.8mm clearance:
    Rear 410mm Kit fits 21" OE wheels w/7.8mm clearance:
    Weight info:
    Feature & Benefit:
    • Highly affordable.
    • Retain stock calipers.
    • A deeper front pads are included in the kit but you can also use stock pads.
    • Kit comes with everything you need for a plug-and-play installation, depending your dust shields it may requires to trim or remove front and rear dust shields to fit larger rotors.
    • Easy bolt on installation, fits under 20" wheels.
    • Increase heat capacity while still saving un-sprung weight.
    • Improve overall performance and look.
    • Front: D603-04 (410mm)
    • Rear: D603-06 (390mm)
    • Rear: D701-05 (410mm)
      • Front: PDTS2021_65 (Larger version)
      • Rear: PD1929
    To assure an optimal performance Brake pad deduct is not available at this time.
    Kit contents
