    • RB Brake Pad for Acura TLX 2021+ ; 2022+ MDX Type S Front Stock Replacement
  • RB Brake Pad for Acura TLX  2021+ ; 2022+ MDX Type S Front Stock Replacement RB Brake Pad for Acura TLX  2021+ ; 2022+ MDX Type S Front Stock Replacement
    MSRP: $220.00
    Now: $210.00
    (You save $10.00 )
    (1 review) Write a Review
    PDTLX-S
    Bulk Pricing:
    Buy in bulk and save
    Bulk discount rates
    • Buy 10 - 29 and get 10% off
    • Buy 30 or above and get 20% off
    RB Pads length is made with a tighter tolerance (than OE pad) agasint OE calipers fitment, so our pads can fit tighter than OE pads w/o causing rocking movement inside the caliper as the car hits a bump which can cause rattling noise and vibration.
    We paid attention to the design details to ensure your brakes always deliver the highest and consitent perormance at all time for a squeaky free and a consistent braking.
    RB pad also has a deeper (larger) lining than OE which can keep your brake cooler.
    • 2
      not for OEM rotors
      Posted by James on Mar 7th 2025
      These are high quality, but are to large for the OEM rotors. This was not clear in the description (11/2024). If using OEM rotors, they will be great at first, but start to squeal when NOT on the brakes due to a small lip contacting the rotor on the inner pads near the centerline. I contacted the company about the issue and have been ghosted for ~5 days.
