Quick view [PD916.PD917] XT910 Street Pad Set for Porsche 996/997 CS2/CS4 Front & Rear MSRP: $400.00 Was: Now: $380.00 Choose Options Compare Quick view RB 2 Pc Rotors - Porsche 987 Boxster-S / Cayman-S / 996 C2 / C4 Front MSRP: $998.00 Was: Now: $948.00 Add to Cart Compare SALE Quick view RB 2pc Rotor Kit (350/350) for Porsche 996 Turbo and GT2/GT3 Pccb Conversion to Iron (P/N 2208 & 2180) MSRP: $3,316.50 Was: $3,150.68 Now: $2,677.00 Choose Options Compare Quick view RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 996 GT2/GT3, 997.1 GT3/Cup; 997.2 Turbo , 992.1 CS Upgrade (P/N 2181-K & 2303-K) MSRP: $3,895.00 Was: Now: $3,700.00 Choose Options Compare Quick view RB BBK (390x34/380x30) for Porsche 996 & 997 (P/N 2432-K & 2433-K) MSRP: $7,850.00 Was: Now: $7,457.50 Choose Options Compare Quick view RB Caliper Spacer Kit for Porsche 996 CS, Cayman/Boxster (96-12) Front & Rear Upgrade to 330/330mm (from 318/299mm) MSRP: $430.00 Was: Now: $408.50 Choose Options Compare Quick view RB OE Caliper BBK (330/330) for Porsche 996/97 CS 2/4. Boxster that come with 318/299 rotors (P/N 2179-K & 2177-K) MSRP: $3,150.00 Was: Now: $2,992.50 Choose Options Compare Quick view RB OE Caliper BBK (350/350) for Porsche 996/997 CS 2/4. Boxster that come with 330/330 rotors (P/N 2179-K & 2180-K) MSRP: $3,150.00 Was: Now: $2,992.50 Choose Options Compare Quick view RB Rotor Kit (350/350) for Porsche 997 & 996 GT2/3 Stock Replacement (P/N 2179 & 2180) MSRP: $3,100.00 Was: Now: $2,945.00 Add to Cart Compare Quick view [PD916.PD917] XT910 Street Pad Set for Porsche 996/997 CS2/CS4 Front & Rear MSRP: $400.00 Was: Now: $380.00 Choose Options Compare Quick view RB 2 Pc Rotors - Porsche 987 Boxster-S / Cayman-S / 996 C2 / C4 Front This rotor fits the following models front: Boxster S 00-10 996/997 Carrera 2 98-08 996/997 Carrera 4 99-08 Cayman S 06-08 Estd wt: 13.8 lbs per rotor OEM# 996-351-405-02-M5 MSRP: $998.00 Was: Now: $948.00 Add to Cart Compare SALE Quick view RB 2pc Rotor Kit (350/350) for Porsche 996 Turbo and GT2/GT3 Pccb Conversion to Iron (P/N 2208 & 2180) Replacement rotor rings: Front: D400-01 Rear: D401-07 MSRP: $3,316.50 Was: $3,150.68 Now: $2,677.00 Choose Options Compare Quick view RB 2pc Rotors (380/380) OE Caliper BBK for Porsche 996 GT2/GT3, 997.1 GT3/Cup; 997.2 Turbo , 992.1 CS Upgrade (P/N 2181-K & 2303-K) This BBK is specially designed and packaged for upgrading your original 350/350mm to the same rotor sizes as 991/992 GT3 380/380mm. Easy 100% bolt on installation. No bleeding to your brake system - Save trouble in bleeding the system if you were to... MSRP: $3,895.00 Was: Now: $3,700.00 Choose Options Compare Quick view RB BBK (390x34/380x30) for Porsche 996 & 997 (P/N 2432-K & 2433-K) Brake pads included in this kit are for street driving, for replacements or off-street applications please contact us or use the links below.Front: PD1395 (RB6L)Rear: PD968 (RB4M3) Follow our brake pad Selection Guide Replacement rotor... MSRP: $7,850.00 Was: Now: $7,457.50 Choose Options Compare Quick view RB Caliper Spacer Kit for Porsche 996 CS, Cayman/Boxster (96-12) Front & Rear Upgrade to 330/330mm (from 318/299mm) Kit includes: 2 ea front caliper spacers for 330 rotors (upgrade from 318mm) 2 ea rear caliper spacers for 330mm rotors (Upgrade from 299mm) 8 ea M12x1.5 alloyed steel longer bolts for BBK Feature & benefit: Instant BBK while stay in OE... MSRP: $430.00 Was: Now: $408.50 Choose Options Compare Quick view RB OE Caliper BBK (330/330) for Porsche 996/97 CS 2/4. Boxster that come with 318/299 rotors (P/N 2179-K & 2177-K) This rotor kit is for upgrading your original rotors from 330/330mm to 350/350mm retaining the use of stock calipers, including necessary caliper spacers & hardware kit for a bolt on installation. Kit Includes: 2 ea light weight front 2 pc rotors... MSRP: $3,150.00 Was: Now: $2,992.50 Choose Options Compare Quick view RB OE Caliper BBK (350/350) for Porsche 996/997 CS 2/4. Boxster that come with 330/330 rotors (P/N 2179-K & 2180-K) This rotor kit is for upgrading your original rotors from 330/330mm to 350/350mm retaining the use of stock calipers, including necessary caliper spacers & hardware kit for a bolt on installation. Kit Includes: 2 ea light weight front 2 pc rotors... MSRP: $3,150.00 Was: Now: $2,992.50 Choose Options Compare Quick view RB Rotor Kit (350/350) for Porsche 997 & 996 GT2/3 Stock Replacement (P/N 2179 & 2180) Brake pads included in this kit are for street driving, for replacements or off-street applications please contact us or use the links below. Front/Rear: PD991/PD1300Follow our brake pad Selection Guide Replacement rotor rings:Front: D400-01Rear:... MSRP: $3,100.00 Was: Now: $2,945.00 Add to Cart Compare Compare Selected × OK
