    • RB 1pc rotor (Slot) - G35 (Brembo) REAR 03-04 - Pair
    MSRP: $250.00
    Now: $237.50
    (You save $12.50 )
    • LBS Per Rotor: 17.5
    • Size: 322x22mm (12.7" x 0.9")
    • Reinforced Ribs for a stronger and cooler disc, alloyed gray iron material upgraded from the OE standard of SAE J431to Class G3000 (30,000 psi in tensile strength), precision CNC machining with a tolerance of .004" and .002", dynamic balancing, performance integrity from design to finish.
    • Electro Deposition Paint (EDP) offers better resistance to corrosion with uniform surface coverage on both edges and recesses (inside vanes). Better appearance and more environmental friendly.
    • Please note the picture is for reference only.
    • RB 1pc rotor  (Slot) - G35 (non-Brembo) REAR 03-04
      MSRP: $78.00
      Now: $73.99
      RB 1pc rotor (Drill+Slot) - G35 (non-Brembo) REAR 03-04
      MSRP: $440.00
      Now: $418.00
    • RB 1pc rotor (Slot) - CROWN VICTORIA REAR 03-04
      MSRP: $271.70
      Now: $258.12
      RB 1pc rotor (Slot) - MUSTANG REAR 94-04
      MSRP: $183.70
      Now: $174.52
      RB 1pc rotor (Slot) - G35X REAR 04-05
      MSRP: $290.40
      Now: $275.88
