    • Tesla Cybertruck OE Caliper BBK (370x34 vs. OE 350x32mm) - Front (P/N 2745-K)
  • front 2 pc rotor fits under OE caliper
  • 380x34mm
  • OE 350x32mm
  • front pad
  • front 2 pc rotor fits under OE caliper 380x34mm OE 350x32mm front pad
    MSRP: $2,100.00
    Now: $1,995.00
    (You save $105.00 )
    2745-K
    Feature & benefits
    • Specially designed and made for an affordable & instant BBK.
    • Retain the use of OE calipers.
    • Easy installation, just swap the rotor and pad, no need to bleed the system.
    • Save unsprung weight while increase the brake power & mileage.
    • Performance improvement.
    • Save time & money.
    • 2 ea Front 2 pc big rotors (370x34 vs. OE 350x32mm).
    • 1 set caliper spacer & hardware kit.
    • 1 set front brake pads.
    Optional:
    • 2 ea Rear 2 pc rotors (356X23mm=OE)
    OE Rotor
    24.17 18.17 42.34 84.68
    RB 2pc Big Rotor
    22.66
    14.77 37.43 74.86
    WT. SAVING -1.51 -3.4 -4.91 -9.82 (-11.6%)
    • Front: D501-02
    • Rear: D401-06
    • Front: PDCT-F_BBK
    • Rear: PDCT-R
    OE wheel specs:
    Front Brake Rotors - Calipers and Pads - Front Brake Rotor (Remove and Install)
    Rear Brake Rotors - Calipers and Pads - Rear Brake Rotor - Base (Remove and Install)
    Other aftermarket brake offer:
