    • RB 2pc Rotors (380x28) for Ford Explorer ST Rear BBK
  • RB 2pc Rotors (380x28) for Ford Explorer ST Rear BBK RB 2pc Rotors (380x28) for Ford Explorer ST Rear BBK RB 2pc Rotors (380x28) for Ford Explorer ST Rear BBK
    MSRP: $1,716.00
    Now: $1,630.20
    (You save $85.80 )
    2668-K
    Kit Content:
    • 2 ea Lightweight 2 pc high performance rotors (380x28 vs. OE 350x26mm)
    • 1 set of extended bracket and mounting hardware
    • 1 set brake pads
    • 1 set stainless steel braided brake line
    This retrofit rotor kit is exclusively made by RB and allows Explorer ST (2020+) owners whether you have base or sports models to upgrade your rear brake to 1" up BBK retain OE calipers. Note Base model owners need to acquire the rear Sports calipers (not included) in order to install the kit.
    Fixed pistons caliper requires more space on outboard than OE floating calipers but it should fit Stock 20"+ wheels w/o issue or you may need to add wheel spacers as needed.
    Rotors are made for a direct bolt-on installation to Explorer spindle.
    Explorer ST Performance rear (RED) calipers are required and are not included in the price which are to be acquired by customer.
    Replacement rotor rings: D501-02
    Replacement brake pads: PD2231
    • RB 4 Pot Caliper BBK (380x28) for Lexus RCF/GSF Rear
      MSRP: $3,200.00
      Now: $3,040.00
    • RB 2pc Replacement Rotor Rings 328x17 for S2000 Rear BBK
      MSRP: $636.90
      Now: $605.06
    • RB 4 Pot Caliper BBK (380x28) for Lexus GS/IS 07+ Rear
      MSRP: $3,200.00
      Now: $3,040.00
    • RB Bracket & Caliper Kit for Ford Explorer ST Perf. Rear BBK (380 vs. OE 355mm) RB Bracket & Caliper Kit for Ford Explorer ST Perf. Rear BBK (380 vs. OE 355mm)
      MSRP: $550.00
      Now: $522.50
    • RB 6 Pot Caliper BBK (380x32mm) for Ford Explorer ST (2020+) Front RB 6 Pot Caliper BBK (380x32mm) for Ford Explorer ST (2020+) Front
      MSRP: $4,026.00
      Now: $3,824.70
