    • RB BBK (370x34) for Tesla M3 Retrofit to Cadillac CTSV V2 or Camaro G5 ZL1 6 Pot Calipers
  • Rotor wt: 23.7 lbs
  • RB BBK (370x34) for Tesla M3 Retrofit to Cadillac CTSV V2 or Camaro G5 ZL1 6 Pot Calipers RB BBK (370x34) for Tesla M3 Retrofit to Cadillac CTSV V2 or Camaro G5 ZL1 6 Pot Calipers Rotor wt: 23.7 lbs RB BBK (370x34) for Tesla M3 Retrofit to Cadillac CTSV V2 or Camaro G5 ZL1 6 Pot Calipers
    Now: $1,460.00
    (You save )
    2609-K
    This BBK rotor kit is exclusively developed by RB to retrofit Model 3 (Standard and Perf. model) to Cadillac CTS-V V2 (or Camaro G5 ZL1) 6 pot calipers, allowing you to upgrade to 370x34mm.
    The kit includes: (Calipers are not included)
    • 2 ea - RB 2pc light wt rotors
    • 1 set - Hardware kit
    • 1 set - RB XT910 brake pads (Optional)
    We have done all the hard work for you to make this rotor kit a true "bolt on" installation, however due to the GM 6 pot caliper has M14 mounting bolts (vs. M3's M12) so you will have to enlarge the spindle bolt holes to 14mm in order to install the calipers. This is the only required modification involved.
    6-pot calipers to acquire: $650 - $750 per pair from eBay
    Be careful not to mis-order 4-pot calipers which are for earlier CTS-V version (=Same as model S front calipers)
    Note this modification process is non-reversible, in other words you can not revert back to 12mm holes once modified.
    Modification to caliper bolt holes:
    6 pot M14x2.0 caliper bolts vs. M3 M12x1.75 bolts
    Customer's install:
    Replacement components:
    Rrotor rings: D501-02
    Brake pads: PD1291-391
    • Installed Rotor wt
      RB Big Rotor Kit (370x34) for Model S/X Front Retrofit to Cadillac CTSV V2/Camaro G5 ZL1 6 Pot Calipers
      MSRP: $1,736.90
      Now: $1,650.06
    • General image FRONT
      RB Rotor Kit (370/365) Retrofit to Cadillac CTSV V2/Camaro G5 ZL1 6 Pot Calipers for Tesla Model S/X Front & OE Caliper Rear (P/N 2606 & 2435)
      MSRP: $2,969.46
      Now: $2,820.99
      RB 6 Piston Caliper (230x37.6) for Camaro G5 Z28 Front (1 caliper)
      MSRP: $2,547.60
      Now: $2,420.22
    • front 2 pc rotor fits under OE caliper 380x34mm
      Tesla Cybertruck OE Caliper BBK (370x34 vs. OE 350x32mm) - Front (P/N 2745-K)
      MSRP: $2,100.00
      Now: $1,995.00
    • RB 6 Pot Caliper BBK (410x34) for Toyota Tundra 2022+ FRONT RB 6 Pot Caliper BBK (410x34) for Toyota Tundra 2022+ FRONT
      MSRP: $4,600.00
      Now: $4,370.00
