    • RB Big Rotor Kit (370x34) for Model S/X Front Retrofit to Cadillac CTSV V2/Camaro G5 ZL1 6 Pot Calipers
  • Installed
  • Rotor wt
  • Behind wheel
  • Installed Rotor wt Behind wheel
    MSRP: $1,736.90
    Now: $1,650.06
    (You save $86.84 )
    2606-K
    This BBK rotor kit is exclusively developed by RB to retrofit Model S/X to Cadillac CTS-V V2 (or Camaro G5 ZL1) 6 pot calipers, allowing you to upgrade to 370x34mm (vs. OE's 355x32mm rotors with 4pot calipers) with heavy duty rotor at the same time.
    The kit includes: (Calipers are not included)
    • 2 ea - RB 2pc light wt rotors (see pic below for the real weight)
    • 1 set - RB XT910 brake pads (best street pads for Tesla)
    • 4 ea - M14x2.0 caliper bolts (brand new)
    We have done all the hard work for you to make this rotor kit a true "bolt on" installation, however due to the GM 6 pot caliper has M14 mounting bolts (vs. S/X's M12) so you will have to enlarge the spindle bolt holes to 14mm in order to install the calipers. This is the only required modification involved.
    6-pot calipers to acquire: $650 - $750 per pair from eBay
    Be careful not to mis-order 4-pot calipers which are for earlier CTS-V version (=Same as model S front calipers)
    Note this modification process is non-reversible, in other words you can not revert back to 12mm holes once modified.
    Modification to caliper bolt holes:
    Rotor Weight:
    6 pot M14x2.0 caliper bolts vs. M3 M12x1.75 bolts
    Customer's install:
    Installed
    • RB BBK (370x34) for Tesla M3 Retrofit to Cadillac CTSV V2 or Camaro G5 ZL1 6 Pot Calipers RB BBK (370x34) for Tesla M3 Retrofit to Cadillac CTSV V2 or Camaro G5 ZL1 6 Pot Calipers
      Now: $1,460.00
    • General image FRONT
      RB Rotor Kit (370/365) Retrofit to Cadillac CTSV V2/Camaro G5 ZL1 6 Pot Calipers for Tesla Model S/X Front & OE Caliper Rear (P/N 2606 & 2435)
      MSRP: $2,969.46
      Now: $2,820.99
    • RB 2pc Rotor Kit (370/365) for Camaro ZL1 G5/Cadillac CTS-V (V2 09-15)/Karma Front & Rear (P/N 2160 & 2140) RB 2pc Rotor Kit (370/365) for Camaro ZL1 G5/Cadillac CTS-V (V2 09-15)/Karma Front & Rear (P/N 2160 & 2140)
      MSRP: $2,878.70
      Now: $2,734.77
      RB 6 Piston Caliper (230x37.6) for Camaro G5 Z28 Front (1 caliper)
      MSRP: $2,547.60
      Now: $2,420.22
    • RB 6 pot Caliper Kit (370x34) for Tundra (2022+), Land Cruiser 300 (2021+) Front Fits Stock 18" Wheels RB 6 pot Caliper Kit (370x34) for Tundra (2022+), Land Cruiser 300 (2021+) Front Fits Stock 18" Wheels
      MSRP: $3,675.00
      Now: $3,490.00
