Quick view Big Brake Kit - 300ZX (or 240SX*) Rear 13" Rotor Kit MSRP: $1,409.10 Was: Now: $1,338.65 Add to Cart Compare Quick view RB 15" BBK (380/380mm) - Front & Rear for 350Z/Infiniti G35/Skyline R34 (P/N 2121-K & 2594-K) MSRP: $7,360.00 Was: Now: $6,998.00 Add to Cart Compare Quick view RB BBK (332x28) - 240SX / 300ZX Front MSRP: $2,695.00 Was: Now: $2,560.00 Add to Cart Compare Quick view RB BBK (390/380mm) - Front & Rear for 350Z/Infiniti G35/Skyline R34 (P/N 2465-K & 2594-K) Retrofit to R35 GTR Brembo 6/4 Pot Calipers MSRP: Was: Now: $4,515.00 Pre-Order Now Compare Quick view Big Brake Kit - 300ZX (or 240SX*) Rear 13" Rotor Kit *240SX has no rear drum brake so it's required to convert the rear to 300ZX (w/drum brake) in order to retain the emergency brake functionality. Replacement parts: Pads: PD1368 1pc rotors: 9036B MSRP: $1,409.10 Was: Now: $1,338.65 Add to Cart Compare Quick view RB 15" BBK (380/380mm) - Front & Rear for 350Z/Infiniti G35/Skyline R34 (P/N 2121-K & 2594-K) Feature & benefit: Kit is made for a 100% bolt-on installation. Rear rotor hats are made with composite metal with aluminum shell with iron sleeve insert and are fully compatible with OE emergency/parking brakes. Kit includes: 2 ea front RB 6 pot... MSRP: $7,360.00 Was: Now: $6,998.00 Add to Cart Compare Quick view RB BBK (332x28) - 240SX / 300ZX Front Kit includes: 2 ea 4 pot calipers 2 ea 2 pc rotors (328x28mm) 2 ea Caliper adaptors 1 set brake pads Replacement components: Rotor rings: D304-06 Brake pads: PD647-391 Wheel fitment template: 2335-K MSRP: $2,695.00 Was: Now: $2,560.00 Add to Cart Compare Quick view RB BBK (390/380mm) - Front & Rear for 350Z/Infiniti G35/Skyline R34 (P/N 2465-K & 2594-K) Retrofit to R35 GTR Brembo 6/4 Pot Calipers Installation note: Kit is made for a 100% bolt-on installation. Installation requires R35 Brembo 6/4 pot calipers which are not included. Rear rotor hats are made with composite metal (aluminum shell with iron sleeve insert) and are fully compatible... MSRP: Was: Now: $4,515.00 Pre-Order Now Compare Compare Selected × OK
