    • RB Stock Size (300x28mm) Brake Kit For Acura TL/TSX/RSX/MDX Front
  • Red
  • Black
  • Anodized finish - Loaded with pads
  • RB Stock Size (300x28mm) Brake Kit For Acura TL/TSX/RSX/MDX Front RB Stock Size (300x28mm) Brake Kit For Acura TL/TSX/RSX/MDX Front Red Black Anodized finish - Loaded with pads
    MSRP: $2,211.00
    Now: $2,100.45
    (You save $110.55 )
    2067-K
    • 2 ea RB 4 pot calipers
    • 2 ea Caliper adaptors
    • 2 ea Light weight 2 Pc rotors
    • 1 set brake pads (optional)
    Rotor wt: 15.2 lbs/ea
    You can order the complete brake kit or the rotors only (w/o calipers) as stock replacement (fits OE floating calipers)
    For the following Acura models/Years:
    • ACURA - CL - 2001 - 2003
    • ACURA - MDX - 2001 - 2002
    • ACURA - MDX - 2003 - 2006
    • ACURA - TL | TL Type 'S' - 1999 - 2008
    • ACURA - TSX - 2004 - 2014
    Rotor weight approx: 15 lbs vs. OE 19 lbs
    • PD647-391
    Replacement rotor ring:
    • D200-01
    • 2067-K
    • RB Caliper BBK 325x30 oversized from stock 300x28mm for Honda  & Acura TL/TSX/RSX Front - Fits 17" Wheels
      MSRP: $2,400.00
      Now: $2,280.00
    • RB 1-Pc Rotor BBK (300x28) For Acura TL/TSX/RSX Front Anodized caliper wt (loaded w/ pads)
      MSRP: $1,760.00
      Now: $1,672.00
    • image_6937
      RB 1-Pc Rotor BBK (324x28) for Acura TL/TSX/RSX Front
      MSRP: $1,975.60
      Now: $1,876.82
    • RB 1pc rotor (Slotted) - Acura TL/TSX/RSX BBK Replacement
      MSRP: $190.00
      Now: $180.00
    • RB Brake Pad for Acura TLX  2021+ ; 2022+ MDX Type S Front Stock Replacement RB Brake Pad for Acura TLX  2021+ ; 2022+ MDX Type S Front Stock Replacement
      MSRP: $220.00
      Now: $210.00
