        • CROSS OVER TUBE
        • MIS FITTINGS
      • All ACCESSORIES
      • CROSS OVER TUBE
      • MIS FITTINGS
        • CROSS OVER TUBE
        • MIS FITTINGS
    • RB System BBK (432/410) for Tesla S Plaid & LR; Front RB Calipers & Rear OE Calipers (Not Included) (P/N 2682-K & 2683-K)
      • All ACCESSORIES
      • CROSS OVER TUBE
      • MIS FITTINGS
  • front kit assembled
  • front kit fits under OE 21"
  • front kit fits under OE 21" w/14mm clearance
  • Front wt
  • rear wt
  • Brake pad
  • RB System BBK (432/410) for Tesla S Plaid & LR; Front RB Calipers & Rear OE Calipers (Not Included) (P/N 2682-K & 2683-K) front kit assembled front kit fits under OE 21" front kit fits under OE 21" w/14mm clearance Front wt rear wt Brake pad
    MSRP: $8,400.00
    Now: $7,980.00
    (You save $420.00 )
    TES-IRP-432.410
    This kit is specially developed for Model S 2021+ Plaid Upgrade for the ultimate track duty:
    • Front calipers are RB6L 6 pot staggered pistons built for heavy track duty - Same calipers as our offer for OE/Brembo replacement calipers for GTR, Mustang GT350/500, Porsche 991, Mclaren 570S/720S.
    • Front rotors are 432x34mm feature RB patented center-mount design, convergent cooling vane two piece rotors. highly efficient in dissipating the heat with plenty of heat capacity to handle Plaid's on track activities for the most demanding and challenging brake duty.
    • Rear rotors also upsized to 410x29mm (from the original 365x28mm) for a balanced brake system.
    Kit inlcudes:
    • 2 ea front two piece huge rotors (432mm/17")
    • 2 ea front RB6L 6 pot calipers
    • 2 ea front caliper adaptors & mounting hardware
    • 2 ea rear two piece big rotors (410mm/16.1")
    • 2 ea rear caliper extended brackets - Retain the use of OE calipers*
    • 1 car set stainless braided brake lines
    • 1 car set brake pads (XT910)
    *To retain parking brake functionality.
    OE
    28.23 20.5 48.73 97.46
    RB 2pc (BBK)
    31.5 27.4 58.9 117.8
    WT. SAVING -3.27 -6.9 -10.17 -20.34
    Front: PD1395A
    Rear: PD1929
    Replacement rotor ring:
    Front: D701-01
    Rear: D701-02
    • 2682-K
    Fits under stock 21" wheels.
    Forum Discussion:
    • https://teslamotorsclub.com/tmc/threads/model-s-plaid-brakes-are-terrible.244778/page-30
    Plaid stock brake is deemed to be insufficient for its weight (4,816 lbs) & the speed it can run.
    Image credit: Fadi Nadar
    IG: Boostitforward
    And when the brakes fail going 140 mph (225 km/h)
    Image credit: speedy_jeff
    IG: https://www.instagram.com/p/CUg1vdMrb35/
    This is how a Plaid truned the street into a race track
    Forum posting/discussion:
    According to the earlier (Sept 9) media the Plaid "Production Car" broke Nürburgring record, but in the recent media (Oct. 14) it disclosed a "Track Pack" will be available to break its own record. (or to correct the brake issue?)
    Since it never be logical for any company that can be so desaprately to break it's own record within one month, so only the latter assumption can be true.
    • Kit contents Front Kit
      MSRP: $4,125.00
      Now: $3,920.00
    • RB OE Caliper BBK (365/355) for Tesla M3 (Std Model) (P/N 2602-K & 2608-K) FRONT
      MSRP: $2,880.00
      Now: $2,686.00
    • RB 6 Pot Front Calipers & OE Rear Caliper BBK (380x34/370x24) for Toyota Supra MK5 (P/N 2657-K & 2656-K) RB 6 Pot Front Calipers & OE Rear Caliper BBK (380x34/370x24) for Toyota Supra MK5 (P/N 2657-K & 2656-K)
      MSRP: $6,138.00
      Now: $5,831.10
    • front 2 pc rotor fits under OE caliper 380x34mm
      Tesla Cybertruck OE Caliper BBK (370x34 vs. OE 350x32mm) - Front (P/N 2745-K)
      MSRP: $2,100.00
      Now: $1,995.00
    • RB 4pot Caliper Front & OE Caliper Rear BBK (324/330) for Acura NSX NA1 (91-05) (P/N 2128-K & 2077) RB 4pot Caliper Front & OE Caliper Rear BBK (324/330) for Acura NSX NA1 (91-05) (P/N 2128-K & 2077)
      MSRP: $3,540.00
      Now: $3,360.00
