        • CROSS OVER TUBE
        • MIS FITTINGS
      • All ACCESSORIES
      • CROSS OVER TUBE
      • MIS FITTINGS
        • CROSS OVER TUBE
        • MIS FITTINGS
    • RB 2 pc Rotor Kit (390/360mm) for Mercedes S63/65, C63S, GT S, SL63/65 AMG 2014+ w/e-PB - Electronic Parking Brake (P/N 2237 & 2357)
      • All ACCESSORIES
      • CROSS OVER TUBE
      • MIS FITTINGS
  • Front dwg
  • Rear dwg
  • Brake pads
  • Front
  • Rear
  • RB 2 pc Rotor Kit (390/360mm) for Mercedes S63/65, C63S, GT S, SL63/65 AMG 2014+ w/e-PB - Electronic Parking Brake (P/N 2237 & 2357) Front dwg Rear dwg Brake pads Front Rear
    MSRP: $3,200.00
    Now: $3,040.00
    (You save $160.00 )
    (1 review) Write a Review
    MB-IRK-2237.2357
    Kit contains:
    • 2 ea Front light wt two piece rotors
    • 2 ea Rear light wt two piece rotors
    • 1 car set brake pads (Optional)
    • Front: D601-05
    • Rear: D407-03
    • Front: PD1291
      Rear: PD1681-391
    Brake pad Selection Guide
    • 5
      Easy peasy
      Posted by Jim Schubert on Nov 25th 2021
      Just installed the new 2-piece rotors on my SL63 amg. The rotors fit perfectly. The rears Have a hole to accommodate the rotor set screw, However, the holes drilled in the front rotors did not lineup for the set screw. Nevertheless, the wheels and wheel lugs hold the front rotors in place perfectly. Break-in was easy as per the instructions with the kit. I'm using the rotors with another manufacturer's ceramic matrix pads and I'm very satisfied with the breaking performance.
    • [PD1291-391] RB Street+ Pad for Aston Martin, Audi RS7, Cadillac, Chevy, Dodge, Ferrari, Jeep,  Mercedes, Rivian Front w/6-Piston Calipers [PD1291-391] RB Street+ Pad for Aston Martin, Audi RS7, Cadillac, Chevy, Dodge, Ferrari, Jeep,  Mercedes, Rivian Front w/6-Piston Calipers
      MSRP: $290.00
      Now: $275.00
    • Stainless Steel Braided Brake Lines (4 line kit) - Mercedes C63 Black Series
      MSRP: $145.20
      Now: $137.94
