- 2 ea Front ccb rotors (380x32mm vs. stock 370x32mm)
- 1 set Caliper spacer kit for the front BBK
- 2 ea Rear ccb rotors (380x30mm vs. stock 350x32mm)
- 1 car set ccb brake pads
- Conversion upgrade to the same rotor sizes as Porsche 991 GT3.
- Direct bolt on installation.
- Retains the use of OE calipers (w/supplied spacers).
- Dramatic unsprung weight reduction.
- Great value for iron rotors conversion upgrade.
- Rotors are made of continuous carbon fiber, much stronger than OE/Brembo composite ccb.
- Rotors are directional vanes for a more efficient cooling.
- Lower maintenance & replacement cost than OE/Brembo CCM rotors.
- Compatible with stock rear drum parking brake.
- Front pad: PD8187-360
- Rear pad: PD4345-360
Replacement discs:
Application notes:
This rotor kit is made for stock iron & pad upgrade conversion to ccb, due to the constraint of caliper pad sizes we do not recommended this setup for heavy tracking.
Installation review:
