UA-215670544-1 Skip to main content
Disk Surface Finish
Open Slot Slotted Only Drilled & Slotted
Open Slot*
Open Slot
See detail view
US Patent #:
7097007
*Currently available only for two-piece rotors.
Advantages:
  • Has the advantages of both drilled & slotted rotors
  • Allows the disc to expand and contract and prevents the disc from cracking or warping
  • Increasing cooling area and retains more friction surface
  • Slots relieves thermal stress
  • Slots are self cleaning and the pad build up will not clog the slots and are exhausted via the rotor edge keeping the disc surface clean
  • Reduces brake pad dust buildup and keeps the wheel clean through vacuum effect
Disadvantages:
  • Cost more to produce
Remarks:
  • Patented design (US Patent #: 7097007)
  • This design optimizes the friction between the pads and disc surface and achieves the highest level of braking performance that no other designs can provide.
  • Minimal brake dust build up on wheels
rb 2 piece rotor
Slotted Only
Straight Slot
Advantages:
  • Helps the gas to escape
  • Keeps disc surface cleaner
  • Easy to produce
Disadvantages:
  • Debris builds up and clogs the slot
    Debris Buildup
Remarks:
Preferred by track racers because slotted rotors are less likely to crack than cross-drilled rotors.
Drilled or Drilled & Slotted
Drilled & Slotted
See detail view
Advantages:
  • Provides better cooling and pad bite
  • Gives "racer's" look
Disadvantages:
    • Reduces friction surface
    • Pads wear out faster
    • Cracks tend to form around drilled holes under hard braking or track racing
Debris Drilled & Slotted
Remarks:
Rotors with drilled holes should only be used for street driving, as these rotors may tend to crack under repeated hard braking or in track racing. When choosing a drilled rotor, be sure that you do NOT choose a rotor that was drilled from an aftermarket blank (like many rotors on the market), as these rotors will not be balanced. All RacingBrake rotors are dynamically balanced as their last step, after slotting and/or drilling to ensure even distribution of mass.
