Quick view RB 2 Pc Rotor Kit (300/303) BBK for Acura NSX NA1 Upgrade to NA2 (P/N 2089 & 2090) MSRP: $2,631.20 Was: Now: $2,499.64 Compare Quick view RB 2 Pc Rotor Kit (324/330) BBK for Acura NSX NA1 (91-96) or NA2 (97-05) (P/N 2076-K & 2077-K) - Caliper Modification is required (See Description) MSRP: $2,860.00 Was: Now: $2,717.00 Choose Options Compare Quick view RB 2pc Replacement Rotor Rings (330x24) - 173mm pcd MSRP: $630.00 Was: Now: $599.00 Add to Cart Compare Quick view RB 2pc Rotors (330/330) for NSX (91-05) Brembo BBK Replacement front and rear (P/N 2156, 2157) MSRP: $2,695.00 Was: Now: $2,560.00 Choose Options Compare Quick view RB Rear BBK Caliper Brackets for NSX 91-96 Upgrade to 330mm (from 282mm) - Price per Pair. MSRP: $510.00 Was: Now: $484.50 Choose Options Compare Quick view RB 2 Pc Rotor Kit (300/303) BBK for Acura NSX NA1 Upgrade to NA2 (P/N 2089 & 2090) Excellent brake upgrade for 91-96 NSX models. Our 2 pc big rotors (12.4 lbs.) weight less than OE 1 pc rotor. May require over-sized wheel. MSRP: $2,631.20 Was: Now: $2,499.64 Compare Quick view RB 2 Pc Rotor Kit (324/330) BBK for Acura NSX NA1 (91-96) or NA2 (97-05) (P/N 2076-K & 2077-K) - Caliper Modification is required (See Description) This affordable BBK is an excellent brake upgrade investment for your NSX. The big rotors can provide larger thermal capacity and more torque leverage to prevent brake fade. With larger thermal capacity and will keep the disc cooler and last longer... MSRP: $2,860.00 Was: Now: $2,717.00 Choose Options Compare Quick view RB 2pc Replacement Rotor Rings (330x24) - 173mm pcd MSRP: $630.00 Was: Now: $599.00 Add to Cart Compare Quick view RB 2pc Rotors (330/330) for NSX (91-05) Brembo BBK Replacement front and rear (P/N 2156, 2157) These rotors are made for NSX Brembo BBK replacement Grand Prix. Replacement rotor ring: Front & rear: 13021/13022 Replacement pads: Front & rear: PD968-391 (Brembo F40) MSRP: $2,695.00 Was: Now: $2,560.00 Choose Options Compare Quick view RB Rear BBK Caliper Brackets for NSX 91-96 Upgrade to 330mm (from 282mm) - Price per Pair. This bracket allows you to use your NSX OE calipers to upgrade rear rotors to 330mm (from 282mm) Please confirm your model or check your existing OE bracket has the same slot width as below in order to reuse the pad spring clips. Replacement brake... MSRP: $510.00 Was: Now: $484.50 Choose Options Compare Compare Selected × OK
