Built for track heat cycles that crack OE EPDM boots
RB High-Temp Silicone
Rated to ~450°F
OE EPDM
Rated to ~300°F
OE EPDM boots tend to crack under repeated high-heat track cycles — RB's silicone boots are built specifically for this.
Real track-proven durability
Documented multi-year use on dedicated track cars, including hard-driven GT3 and EVO platforms.
Right boot for the job
Standard black boots for street use, high-temp blue silicone for track days — choose based on how the car is driven.
Why OE boots fail on track
OE dust boots are made of EPDM, which performs fine for typical street use, but under the sustained high heat of track driving the material tends to crack, sometimes within a single track day on hard-driven cars.
Why silicone solves it
RB's high-temperature blue silicone boots are rated to roughly 450°F, well above the ~300°F rating of standard EPDM, so they hold up through repeated heat cycles instead of hardening and cracking.
Choosing the right boot
Standard black boots are appropriate for street-driven cars. High-temp blue silicone boots are recommended for cars that see regular track time or sustained hard braking, where OE-style boots are most likely to fail.
