Quick view [PD-AM-360] RB Pads Kit for CCM Rotors - Aston Martin DB9 04-16; Vanquish, 12-18; Vantage V12S 13+ Front and Rear (PD1395B & PD1165) - ST600 MSRP: Was: Now: $0.00 Choose Options Compare Quick view Carbon Ceramic Rotor Kit (394/360) for Aston Martin DB9, Vanquish, Vantage V12S CCB Rotor Replacement, Front & Rear (P/N 2C06 & 2C97) MSRP: $13,310.00 Was: Now: $12,644.50 Pre-Order Now Compare Quick view RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DB9, Vanquish, Virage, Vantage V12S; Front and Rear (P/N 2409 & 2410) MSRP: $3,500.00 Was: Now: $3,325.00 Choose Options Compare Quick view [PD-AM-360] RB Pads Kit for CCM Rotors - Aston Martin DB9 04-16; Vanquish, 12-18; Vantage V12S 13+ Front and Rear (PD1395B & PD1165) - ST600 You save 10% when buying front and rear pads together vs. purchasing separately. Â Here is the link if you would like to purchase individually: Front:Â PD1395B-360 Rear:Â PD1165-360 MSRP: Was: Now: $0.00 Choose Options Compare Quick view Carbon Ceramic Rotor Kit (394/360) for Aston Martin DB9, Vanquish, Vantage V12S CCB Rotor Replacement, Front & Rear (P/N 2C06 & 2C97) WHY RacingBrake is your first choice on CCM Brakes? Kit Includes: 2 ea front CCB rotors (394x36mm) 2 ea rear CCB rotors (360x32mm) 1 set CCB brake pads (optional) Replacement rotor rings: Front: 39 MSRP: $13,310.00 Was: Now: $12,644.50 Pre-Order Now Compare Quick view RB 2pc Rotor Kit (394/360) CCB to Iron Conversion for Aston Martin DB9, Vanquish, Virage, Vantage V12S; Front and Rear (P/N 2409 & 2410) This rotor and pad kit is specially made for converting OE CCB to Iron rotors with a 100% bolt on installation. Not only it can eliminate that annoying squeaks from OE CCB rotors but lower your... MSRP: $3,500.00 Was: Now: $3,325.00 Choose Options Compare Compare Selected × OK
