Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view GM OE CCM Rotors (390x32) for Camaro G5 Z28 Rear (M14 Lug bolt) Price is for 2 Rotors MSRP: $4,730.00 Was: Now: $4,493.50 Compare Quick view GM/Brembo CCB Brake Kit (394/390) for Camaro G5 (10-15) & CTSV V2 Upgrade (PN: 2C38 & 2C86) MSRP: $14,500.00 Was: Now: $13,800.00 Choose Options Compare Quick view RB 2pc Rotor Kit (394/390) CCM Conversion to Iron rotors for Camaro Z/28 2012+ (P/N 2381 & 2382) MSRP: $3,100.00 Was: Now: $2,945.00 Choose Options Compare Quick view RB Light Wt Rotor Hat for Camaro G5 Z28 Rear & G6 Upgrade to CCM Rotors (390x32mm) w/Z28 Calipers only - Not compatible with G6 Rear Calipers (2 ea. Incl. Hardware Set) MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare SALE Quick view RB-CCB Carbon Ceramic Rotor Kit (394/390) for Camaro Z28 Replacement Front & Rear (P/N: 2C38 & 2C83) MSRP: $13,000.00 Was: $12,500.00 Now: $11,250.00 Choose Options Compare Quick view RB-CCB Disc (390x32x66mm) - Price per pair. MSRP: $4,490.00 Was: Now: $4,266.00 Choose Options Compare Quick view RB-CCB Disc (410x36mm) - Price per pair. MSRP: $5,455.00 Was: Now: $5,180.00 Add to Cart Compare Quick view RB-CCB System Kit (394/390) for Camaro G5 & Cadillac V2 Upgrade (P/N 2C38-K & 2C83-K) MSRP: $16,500.00 Was: Now: $15,675.00 Choose Options Compare Quick view [PD-ZR1-360] Brake Pads for CCM Rotors - Corvette ZR1, Camaro Z28, Viper ACRE, Ferrari F458/California & 488, Alfa Rome, Nissan GT-R (w/RB rotors) & RB 6/4 Caliper Kit - FRONT & REAR: (PD1395 & PD1165) Installation Note: For Ford GT350 6 pot calipers installation it requires a hardware kit (included on request) to create proper tension from the hold down spring to the brake pads to avoid rattling. Brembo OE ZR1 brake pad dimension flow as seen on... MSRP: Was: Now: $1,050.00 Choose Options Compare Quick view GM OE CCM Rotors (390x32) for Camaro G5 Z28 Rear (M14 Lug bolt) Price is for 2 Rotors 1. Rotors are brand new & unused. 2. Drawing picture shown the rotor assembly with RB light weight hats, and is for showing dimensions only, OE rotors come with stainless steel hats. MSRP: $4,730.00 Was: Now: $4,493.50 Compare Quick view GM/Brembo CCB Brake Kit (394/390) for Camaro G5 (10-15) & CTSV V2 Upgrade (PN: 2C38 & 2C86) Kit contains: 2 ea. Front Z28 6-piston calipers 2 ea. Rear Z28 4-piston calipers 2 ea. Front CCM rotors - OE Brembo made of chopped (short) carbon fibers 2 ea. Rear CCM rotors - OE Brembo made of chopped (short) carbon fibers 1 car set street pads 1 car... MSRP: $14,500.00 Was: Now: $13,800.00 Choose Options Compare Quick view RB 2pc Rotor Kit (394/390) CCM Conversion to Iron rotors for Camaro Z/28 2012+ (P/N 2381 & 2382) Kit includes: 2 ea front 2 pc rotors 2 ea rear 2 pc rotors 1 car set brake pads (optional) Replacement brake pads: Front: PD1395Rear: PD1165 Rotor replacement ring: Front: D602-01Rear: D601-09 MSRP: $3,100.00 Was: Now: $2,945.00 Choose Options Compare Quick view RB Light Wt Rotor Hat for Camaro G5 Z28 Rear & G6 Upgrade to CCM Rotors (390x32mm) w/Z28 Calipers only - Not compatible with G6 Rear Calipers (2 ea. Incl. Hardware Set) Kit includes: 2 ea light wt composite hats. 20 sets hardware kits OE Stainless Steel Hat:RB Composite Hat: MSRP: $1,936.00 Was: Now: $1,839.20 Add to Cart Compare SALE Quick view RB-CCB Carbon Ceramic Rotor Kit (394/390) for Camaro Z28 Replacement Front & Rear (P/N: 2C38 & 2C83) Kit includes: 2 ea Front ccb rotors (394x36mm) 2 ea Rear ccb rotors (390x32mm) 1 car set CCB brake pads (Optional) Feature & benefits: Discs are made of long carbon fibers (vs.. OE/Brembo Chopped fibers) for improved performance & lasting... MSRP: $13,000.00 Was: $12,500.00 Now: $11,250.00 Choose Options Compare Quick view RB-CCB Disc (390x32x66mm) - Price per pair. Discs are made for a direct replacement to OE/Brembo with long carbon fibers. See tech info. MSRP: $4,490.00 Was: Now: $4,266.00 Choose Options Compare Quick view RB-CCB Disc (410x36mm) - Price per pair. MSRP: $5,455.00 Was: Now: $5,180.00 Add to Cart Compare Quick view RB-CCB System Kit (394/390) for Camaro G5 & Cadillac V2 Upgrade (P/N 2C38-K & 2C83-K) Kit contains: 2 ea. RB 6-piston caliper 2 ea. RB 4-piston caliper 2 ea. Front CCM rotor built with RB long (continuous) carbon fibers 2 ea. Rear CCM rotor built with RB long (continuous) carbon fibers 1 car set caliper adaptors & hardware 1 car set... MSRP: $16,500.00 Was: Now: $15,675.00 Choose Options Compare Compare Selected × OK
