          • DBX 707 (2020 - )
          • DB11_12 (2017 - )
    • RB BBK (410/390) for Tesla Model S/X - Front RB6M Calipers & Rear OE Calipers (Not Included) (P/N 2658-K & 2643-K) Note: This REAR Kit is Not Compatible with Older S (before 2017) and Perf. Model (After 2017) w/Brembo Rear (3rd) Parking Brake
          • DBX 707 (2020 - )
          • DB11_12 (2017 - )
  • 2643 REAR
  • RB BBK (410/390) for Tesla Model S/X - Front RB6M Calipers & Rear OE Calipers (Not Included) (P/N 2658-K & 2643-K) Note: This REAR Kit is Not Compatible with Older S (before 2017) and Perf. Model (After 2017) w/Brembo Rear (3rd) Parking Brake 2643 REAR
    MSRP: $6,850.00
    Now: $6,500.00
    (You save $350.00 )
    TES-IRP-05
    This kit is made for Model S/X 2017+ w/rear integrated dual function (parking & braking) single piston floating calipers. (Not for sports model with a 3rd parking brake.)
    Kit will oversize your original rotors from 355/365 to 410/390mm. It includes all neccessary components for a complete brake system upgrade (except the OE rear calipers)
    • 2 ea front two piece rotors
    • 2 ea front 6 pot calipers (includes brake pads)
    • 2 ea front caliper adaptors
    • 2 ea rear two piece rotors
    • 2 ea rear caliper extended brackets (Reuse your OE calipers*-Not included)
    • 1 set rear brake pads
    • 1 car set brake lines
    *You must reus OE calipers in order to retain parking brake functionality.
    Brake pads included in the kit are for street driving, for off-street applications please use the links below.
    Front: PD1666 (RB6M3 caliper)
    Rear: PD1929 (for OE caliper)
    • Front 2658
    Replacement rotor ring:
    Front: D601-11
    Rear: D603-06
    • Kit contents Front Kit
      MSRP: $4,125.00
      Now: $3,920.00
    • RB CCB System Kit (390/390) for Tesla Model S & X Front & Rear (P/N 2C49-K & 2R16-K). Note - This kit is compatible only for 2017+ w/Integrated rear e-Parking brake. RB CCB System Kit (390/390) for Tesla Model S & X Front & Rear (P/N 2C49-K & 2R16-K). Note - This kit is compatible only for 2017+ w/Integrated rear e-Parking brake.
      MSRP: $15,950.00
      Now: $15,152.50
      MSRP: $8,400.00
      Now: $7,980.00
    • RB CCB System Kit (390/360) for Tesla Model S & X Front & Rear (P/N 2C49-K & 2C33-K), Compatible with a Separate Parking Brake (Not compatible w/ dual function e-PB) RB CCB System Kit (390/360) for Tesla Model S & X Front & Rear (P/N 2C49-K & 2C33-K), Compatible with a Separate Parking Brake (Not compatible w/ dual function e-PB)
      MSRP: $16,500.00
      Now: $15,675.00
    • RB Rotor Kit (355/355mm) for Tesla M3 (Standard or Perf. Model) OE Calipers BBK (P/N 2603-K & 2608-K) RB Rotor Kit (355/355mm) for Tesla M3 (Standard or Perf. Model) OE Calipers BBK (P/N 2603-K & 2608-K)
      MSRP: $2,860.00
      Now: $2,717.00
