        • CROSS OVER TUBE
        • MIS FITTINGS
      • All ACCESSORIES
      • CROSS OVER TUBE
      • MIS FITTINGS
        • CROSS OVER TUBE
        • MIS FITTINGS
    • Save 10% on RB CCB BBK Bundle (410/410) for Tesla S Plaid & LR (PN 2R59 & 2R49) - Fits Direct Under OE Calipers (Front 4 pot, Rear 1-pot)
      • All ACCESSORIES
      • CROSS OVER TUBE
      • MIS FITTINGS
  • Front OE wt
  • rear ccb wt
  • Save 10% on RB CCB BBK Bundle (410/410) for Tesla S Plaid & LR (PN 2R59 & 2R49) - Fits Direct Under OE Calipers (Front 4 pot, Rear 1-pot) Front OE wt rear ccb wt
    MSRP: $13,900.00
    Now: $13,200.00
    (You save $700.00 )
    TES-CRK-S410.410
    Rotor & Pad Installation Video
    • 2 ea front ccm rotors (410x33mm)
    • 1 set front OE caliper spacers & mounting hardware
    • 2 ea rear ccm rotors (410x29mm)
    • 1 set rear OE caliper bracket & mounting hardware
    • 1 car set brake pads made for CCB rotors (larger front pad)
    • 1 car set rotor retaining screws
    • 1 car set SS braided brake lines
    • Requires 20" wheels with some trimming on dust shield edges for larger rotors.
    • Fits direct under OE 4 pot front and 1 pot rear clipers.
    Weight reduction:
    OE IRON 28.2 22.5 52.5 105
    RB CCM BBK*
    15 11.8 26.8 53.6
    WT SAVING
    13.2
    10.7
    23.9
    47.8(46%)
    *Rear wt based on OE Rear 365x28mm
    • Easy to install.
    • All discs are made with RB Gen 4 CCM technology; long (continuous) carbon fibers and angle vanes.
    • CCM rotors have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack like conventional iron rotors due to the heat. More advantageous for tracking/racing with proper brake pads.
    • Literally no brake dust.
    • Improve driving comfort.
    Compare RB rotor material - Continuous carbon fibers vs. OE/Brembo's chopped carbon fibers
    In Cooling Vanes - Angle (directional) vs. Straight (Better cooling efficiency)
    In Finish - Fully machined vs. as casted (Better look and balance)
    Avoid:
    Learn more about the different generation on CCM rotors.
    • Save 10% on RB CCB BBK Bundle (410/365) with Optional Rear BBK for Tesla X Plaid (PN 2R57 & 2R46) - Fits OE Calipers oe front wt
      MSRP: $13,460.00
      Now: $12,970.00
      MSRP: $8,400.00
      Now: $7,980.00
    • RB CCB BBK (390/365) Bundle Kit (With 390/390 Option) for Tesla Plaid & LR Upgrade (PN 2R47 & 2R46) - Fits OE Calipers front kit installed
      MSRP: $9,600.00
      Now: $9,120.00
    • Kit contents Front Kit
      MSRP: $4,125.00
      Now: $3,920.00
    • SALE
      RB-CCB Rotor OE Caliper Kit (390x36) for Tesla S/X Plaid & Long Range Front w/OE Black Calipers (Does Not Fit Non Plaid Models) RB-CCB Rotor OE Caliper Kit (390x36) for Tesla S/X Plaid & Long Range Front w/OE Black Calipers (Does Not Fit Non Plaid Models)
      MSRP: $6,000.00
      Was: $5,700.00
      Now: $5,400.00
