    • Save 10% on RB 2pc Rotor Kit (345/345) for Supra MK5 & BMW Z4 19+/M3 G80 (P/N 2653 & 2654) - Note: the rear rotors are for Red Bracket (Not w/Gray Calipers)
  • Front rotor
  • Front OE wt
  • Front RB wt
  • Rear rotor
  • Rear OE wt
  • Rear wt
  • Front pad
  • Rear pad
  • Save 10% on RB 2pc Rotor Kit (345/345) for Supra MK5 & BMW Z4 19+/M3 G80 (P/N 2653 & 2654) - Note: the rear rotors are for Red Bracket (Not w/Gray Calipers) Front rotor Front OE wt Front RB wt Rear rotor Rear OE wt Rear wt Front pad Rear pad
    MSRP: $2,453.00
    Now: $2,330.35
    (You save $122.65 )
    SUP-IRK-01
    Note on dimensions deviation to OE.
    • Front rotors are made to 345x36 (vs. OE 347x36) which can eliminate the rusty lips that are not contacted by brake pads.
    • Front rotors have 71mm annulus for 70mm deep RB pads and OE 75mm deep pads will not fit (unless modified).
    • Rear rotors are made to 345x24 (vs. OE 345x22) - Thicker rear rotors can provide extra thermal capacity for extended rotor life especially beneficial for someone to track the car.
    Rather than copying the dimensions from OE like others, we purposely made rotors to fit better than OE, based on our decades of knowledge and experience, so that Supra owners can install and run them better than OE and/or other competitions.
    We can also confirm no fitment issue to OE calipers and pads based on our fitment test before release.
    Similarly to our BMW M3, EVO 8/9/10 etc kits. Therefore no duplicate OE dimension rotors are to be made nor available.
    The brake pads included in the car kit are for street use, for off street application, other compounds are available:
    Front: PD1867
    Rear: PD2220
    Front: D408-05
    Rear: D404-02
    ROTOR WT.  (LBS) FRONT REAR TOTAL
    OE 27.65 18.52 47.2/SIDE
    RB 22.13 17 39.1/SIDE
    SAVING 5.52 1.52 7.04/SIDE
    SAVING 11.4 3.04 14.08/CAR
    • Save 10% on RB 2pc Rotor Kit (345/308) for VW MKV/MKVI R32 & Golf R (P/N 2299 & 2182) Save 10% on RB 2pc Rotor Kit (345/308) for VW MKV/MKVI R32 & Golf R (P/N 2299 & 2182)
      MSRP: $2,050.00
      Now: $1,947.50
    • RB 2pc Rotor Kit (345/300) for Audi S4 04-09 (P/N: 2475/2661) rear
      MSRP: $2,607.00
      Now: $875.99
    • Save 10% on RB 2pc Rotor Kit (390x36/380x28) for BMW M5 F90 Stock Replacement (P/N 2644 & 2645) Front 2644
      MSRP: $2,950.00
      Now: $2,802.50
    • (Not Actual rotor) 2104 is straight slots. RB 2pc Rotor (312x20) Stock Repl for BMW M3 (E36) Rear
      MSRP: $896.50
      Now: $851.68
      RB 2pc Rotor (330x22) for BMW M3 (E46 ZCP) / Z4M Rear
      MSRP: $1,086.80
      Now: $1,032.46
