    • RB Carbon Ceramic Brake Kit (394/390) for McLaren 765LT, 620R (P/N: 2R36-K & 2R80-K)
  • Front 6 Pot
  • Front rotor
  • Rear 4 Pot
  • Rear rotor
  • Front RB caliper
  • Rear RB caliper
  • RB Carbon Ceramic Brake Kit (394/390) for McLaren 765LT, 620R (P/N: 2R36-K & 2R80-K) Front 6 Pot Front rotor Rear 4 Pot Rear rotor Front RB caliper Rear RB caliper
    MSRP: $19,600.00
    Now: $18,620.00
    (You save $980.00 )
    RCCB-MC-394.390
    Kit Includes:
    • 2 ea front CCM rotors (394x36mm)
    • 2 ea rear CCM rotors (390x34mm)
    • 2 ea front 6 pot RB calipers & adaptors
    • 2 ea rear 4 pot RB calipers & adaptors
    • 1 car set brake pads (Optional)
    RB CCB system kit advantage:
    • System is designed, engineered, and manufactured by RB.
    • Caliper bodies are precisely machined from forged aluminum alloy, stronger and more rigid than OE calipers.
    • Calipers are made with internal dust seals, no dust boots to burn out like OE.
    • Caliper pistons are machined from 304SS bar stock with very low heat transfer rate (~1/10 of aluminum), machined with thin wall cut to save the weight, excellent dimensional stability under elevated temperature, maintain one solid piece integrity - Never deformed or corroded.
    • Pistons barrels are finished with lapping finish before receiving chrome plating to assure smooth seal movement for the lasting durability.
    • Our calipers NEVER requires anti knock-back springs like others.
    • CCM discs (front and rear) are made with long carbon fibers (vs. OE chopped fibers), stonger and more durable than OE.
    • Brake pads are fully compatible with Corvette ZR1/Camaro Z28, Ferrari F430 Scuderia, F458, California so lots of choice at lower cost than OE.
    Design & Installation notes:
    • Brake kit is made for a direct bolt-on installation to OE spindles w/o requiring any modification.
    • Calipers and rotors are fully interchangeable & compatible with OE
    Caliper design and construction.
    Brake Bias Comparison:
    Brake kit wheel fitment template:
    • Front: 2C61-K
    • Rear: 2C62-K
    Forum discussions:
    New Racing Brake long fiber carbon rotors with calipers full brake kit: first impressions on track
    A Brake System Upgrade Beyond Rotor & Pad Replacement
    • RB-CCB Replacement Rotors (390/390) for McLaren 620R, Senna/765LT Front & Rear (P/N 2R36 & 2R80) front wt
      MSRP: $16,000.00
      Now: $15,200.00
    • RB Carbon Ceramic Brake Kit (394/380) for McLaren 600LT, 720S, 750S, GT, Artura (P/N: 2C61-K & 2R37-K) Front 6 Pot
      MSRP: $18,900.00
      Now: $17,890.00
      MSRP: $16,737.88
      Now: $15,900.99
    • RB-CCB System Kit (394/390) for Camaro G6 & Cadillac V3 (P/N 2C85-K & 2C86-K)
      MSRP: $16,800.00
      Now: $15,960.00
    • Carbon Ceramic Big Brake System Kit (394/410) for Ferrari F50 (95-97) Front & Rear (P/N 2R63-K & 2R64-K) front kit
      MSRP: $36,000.00
      Now: $34,200.00
