    • Carbon Ceramic Big Brake System Kit (394/410) for Ferrari F50 (95-97) Front & Rear (P/N 2R63-K & 2R64-K)
  • front kit
  • rear kit
  • Carbon Ceramic Big Brake System Kit (394/410) for Ferrari F50 (95-97) Front & Rear (P/N 2R63-K & 2R64-K) front kit rear kit
    MSRP: $36,000.00
    Now: $34,200.00
    (You save $1,800.00 )
    FF50-CRK
    Kit Includes:
    • 2 ea Front RB 6-pot brake calipers (vs. OE 4-pot calipers)
    • 2 ea front CCB rotors (394x36mm vs. stock 355x32mm)
    • 2 ea Front caliper adaptors w/hardware
    • 2 ea Rear RB 6-pot brake calipers (vs, OE 4-pot calipers)
    • 2 ea Rear caliper adaptors w/hardware
    • 2 ea Rear CCB rotors (410x29mm vs. stock 335x32mm)
    • 2 ea rear parking brake caliper adaptors (hardware incl.)
    • 1 car set CCB brake pads
    • 1 car set SS brake lines
    • Front: PD1666-360
    • Rear: PD1666-360
    Replacement brake discs:
    • Front: CR32
    • Rear: CR29
    Wheel Ftiment Templates:
    • Front: 2R63-K
    • Rear: 2R64-K
    Design notes:
    This carbon ceramic system bbk is exclusively designed and custom built for Ferrari F50 conversion upgrade.
    Calipers are upgraded to 6/6 pot over OE's 4/4 pot.
    Rotors are over-sized but are staggered to improve the braking performance of mid engine vehicles like F50.
    This brake kit not only will update F50 brakes with modern technology for performance improvement but also provide visual appeal (more proportion) for a staggered wheel size setup.
    These upgrades reduce unsprung weight, eliminate brake fade during track use, and improve pedal feel, without disrupting the car's classic aesthetic.
    Design Criteria:
    Feature & benefit:
    • Replacing stock rusty & outdated iron rotors to the modern ccb rotors.
    • Easy bolt-on installation.
    • RB discs are made with Gen 4 CCB technology; long (continuous) carbon fibers for increased strength and durability and angle vane for more efficient heat dissipation.
    • CCB rotors have "Diamond hard" surface with excellent "Thermal Stability" so they will NEVER Wear*, Warp, or Crack (due to the heat). More advantageous for tracking/racing with proper brake pads.
    • Literally no brake dust.
    • Improve driving comfort.
    To determine a CCB rotor serviceability, we recommend visual inspection by monitoring the rotor surface, than weight measurement suggested by OE/Brembo, which can be misleading w/o factoring in the weight of braking debris deposited in the drilled holes.
    *If a CCB rotor is frequently running over the threshold temperature, the carbon will start oxidizing (losing carbon) resulting "pitted" surface which would act like a super grinder that can quickly wear out a new set of pad in just a few laps.
    Avoid:
    F50 Car Specs. (Source: https://www.supercars.net/blog/all-brands/ferrari/ferrari-f50/)
    • Manufacturer: Ferrari S.p.A.
    • Production:1995–1997
    • Units:349 produced
    • Assembly: Maranello, Italy
    • Designer: Pietro Camardella and Lorenzo Ramaciotti
    • Class: Sports car (S)
    • Body style: 2-door Targa
    • Layout: Rear mid-engine, RWD
    • Engine:7L DOHC 65 degree Tipo F130B V12
    • Power:382 kW (519 PS; 512 hp)
    • Transmission:6-speed manual
    • Wheelbase:2,580 mm (101.6 in)
    • Length:4,480 mm (176.4 in)
    • Width:1,986 mm (78.2 in)
    • Height:1,120 mm (44.1 in)
    • Curb weight:1,400 kg (3,080 lb)
    • Predecessor: Ferrari F40
    • Successor: Ferrari Enzo
    • Carbon Ceramic Brake System Kit (420/410) for Tesla Plaid & LR Front & Rear (P/N 2R44-K & 2R49-K) Carbon Ceramic Brake System Kit (420/410) for Tesla Plaid & LR Front & Rear (P/N 2R44-K & 2R49-K)
      MSRP: $17,850.00
      Now: $16,960.00
    • Carbon Ceramic Brake System Kit (420/410) for Tesla X Plaid Front & Rear (P/N 2R58-K & 2R49-K) Carbon Ceramic Brake System Kit (420/410) for Tesla X Plaid Front & Rear (P/N 2R58-K & 2R49-K)
      MSRP: $17,850.00
      Now: $16,960.00
    • Tesla Cybertruck Big Brake Kit (410/400) Front & Rear (P/N: 2723-K, 2756-K) Tesla Cybertruck Big Brake Kit (410/400) Front & Rear (P/N: 2723-K, 2756-K)
      MSRP: $4,500.00
      Now: $4,195.00
    • RB Carbon Ceramic Brake Kit (394/390) for McLaren 765LT, 620R (P/N: 2R36-K & 2R80-K) Front 6 Pot
      MSRP: $19,600.00
      Now: $18,620.00
    • RB Carbon Ceramic Brake Kit (394/380) for McLaren 600LT, 720S, 750S, GT, Artura (P/N: 2C61-K & 2R37-K) Front 6 Pot
      MSRP: $18,900.00
      Now: $17,890.00
